HK problem - Road Glide Forums
post #1 of 14 (permalink) Old 08-14-2014, 06:18 PM Thread Starter
HK problem
Some one a while back had a problem the same as me. I can't find or remember who.
The problem is with the Aux input playing my mp3 and CD player The system plays fine when bike is sitting still running or off. When riding down the road the sound on the CD & MP3 will cut out for a split second , every 5 or 10 seconds if the volume is turned up. The radio plays perfect at any volume.
When sitting still , it all play fine at any volume. Damn HK ! Any Ideas ? I don't believe its a wiring problem or Amp problem since the radio works fine. I also switched mp3s and connection wire.
Big_gary is online now
post #2 of 14 (permalink) Old 08-14-2014, 06:39 PM
thedude's Avatar
Mine started out kind of like that. I thought it was just a bad cable from the ipod interface but now nothing works at all. The screen lights up like it is playing but no sound on ipod or radio. When it started it would play when I switched to the radio but no go now. Goes in next week for a swap since it is still under warranty.
thedude is offline
post #3 of 14 (permalink) Old 08-14-2014, 08:02 PM
I am not sure if I am who you are referring to but I commented on this problem on another persons thread. I have this issue and it's been in resolved for 4 months now on my 2013 CVO. It started after I had the bike for about 7 months while on a road trip. Now 4 months later, two trips to the service department, this last time they have had my bike 3 weeks and after countless calls by my dealership to Harley Tech Services, they replaced the radio, amp, interface and speakers and this problem is still unresolved. I am at the end of my patience, not so much with my dealership but with Tech Services and their approach to getting to the bottom of the problem. I called the owner tonight to share my displeasure, I am calling Harley Customer Service tomorrow and am picking my bike up so I can ride while they are all trying to find the solution. My service guys did tell me if you turn the AVC down to zero bars it is less noticeable than if you have it at 1 or more bars. They were saying Harley Tech was telling them the radio doesn't work if you go higher than 2 bars...I called BS. If they don't want it to go above 2 bars then they shouldn't have it programmed to go up to 4 bars. So, long story short I am having my left speaker drop out and my IPod also keeps going back to the sonf it picked to be the first in the loop and will only play a small position of the songs I have loaded. At first My service guys couldn't get the speaker to drop out when it's sitting idling but they put the fans on the motor and let it idle for about 10 minutes and it started doing it. Right now, Harley Tech Services and my local service department are waiting on Harley Engineering to respond to emails that have been sent to them outlining this problem and asking them for assistance. So as I wait for them to figure this out I guess I will ride without use of my radio.
FireBall is offline
post #4 of 14 (permalink) Old 08-15-2014, 06:25 AM Thread Starter
That sucks that they replaced everything and you still have problems. I'm going to try the AVC adjustment but don't see why that would affect anything seeing I've had it on and wide open since I owned the bike.
I'm up in the air about sending the HK into Iron Cross or just going aftermarket.
post #5 of 14 (permalink) Old 08-15-2014, 06:27 AM Thread Starter
Hope you don't have the same results as fireball.
post #6 of 14 (permalink) Old 08-15-2014, 07:33 AM
hometoast's Avatar
do it You'll wonder why you didn't earlier.
2013 Candy Orange FLTRX
hometoast is offline
post #7 of 14 (permalink) Old 08-15-2014, 08:50 AM Thread Starter
But its my rain bike.
post #8 of 14 (permalink) Old 08-15-2014, 08:52 AM
ERod62's Avatar
Don't bother with the HK unit if under warranty get HD to fix it. Replace it with an aftermarket one many great features the HK don't have like Bluetooth, USB, better tuning and analog outputs for amp set up.
Sale the HK unit on eBay +$300, Alpine 149 $200/ biketronics kit $200/ case of beer for install $20.00 total investment $120 and better sound with update options. 😃
ERod62 is offline
post #9 of 14 (permalink) Old 08-15-2014, 09:07 AM
hometoast's Avatar
So is mine. Been parked outside in a couple of those "2 inches in an hour" kind of storms. No issues. Though I know it might just be good luck.
post #10 of 14 (permalink) Old 08-15-2014, 09:22 AM Thread Starter
What receiver do you have ? Do you have a rain cover on it ? If so which one ? What remote kit you using. I see folks having problems with those too.
Radio suggestions to replace HK? Sincecrazy Audio 34 01-27-2012 06:14 PM
Converting HK head unit to RCA outs abone Audio 1 05-07-2011 07:36 PM
Rear speaker output from HK head unit Mlangfelder Audio 6 03-29-2011 02:23 PM
Question Can I put an HK in an 04 ebertf Aftermarket Accessories 5 01-12-2011 05:41 PM
Wanted...HK cb module Redfish-Joe Classifieds Archive (3 months old+) 0 12-19-2010 11:28 AM
