What are these, and do I use them for a speaker change? - Road Glide Forums
post #1 of 5 (permalink) Old 02-09-2015, 08:41 AM Thread Starter
kyle31490's Avatar
So I got a new set of Memphis Audio 5x7 car speakers from the previous owner when I bought the bike. I hear they will be better than the Hog Tunes that are in there now.
So they came with 2 of these box things.
Are these crossovers? If so, do I wire the main power and ground to the exsusting wires that go to the hog tunes?
Thanks for any info. I know very little about stereos.
kyle31490 is offline
post #2 of 5 (permalink) Old 02-09-2015, 09:13 AM
They look like Crossovers but I dont know how to wire them.
Lunchbox
2001 HD FLTRI
Lunchboxx is offline
post #3 of 5 (permalink) Old 02-09-2015, 10:33 AM Thread Starter
kyle31490's Avatar
Right now the blue wire going to the Hogtunes speaker is the hot and the black wire going to it is the ground.
So, I should in theory be able to solder the red wire on the crossover to the blue wire that's in the bike now, and solder the 2 black wires together, correct?? There is 1 crossover for each speaker so id do the same on both sides.
post #4 of 5 (permalink) Old 02-09-2015, 01:56 PM
stripclub's Avatar
They look like crossovers to me also, a crossover is wired in between the amp outputs and usually a tweeter, there function is to take the low frequency out of the tweeters, for realibility,and crisp undistorted highs, you definately wouldn't want to wire those in on the woofer side of speakers, they should wire + to + and - to - from amp output to input of crossover, then same + to + and - to - from crossover out to tweeter in.
stripclub is offline
post #5 of 5 (permalink) Old 02-09-2015, 02:21 PM Thread Starter
kyle31490's Avatar
Ok great. I will solder the crossovers in before the speakers then. I'll mount them to the inner with 3m tape. The connectors are different sizes going to the speakers so should be hard to mess that up. I'll shorten the wires way down on the crossovers to avoid un-needed bulk and solder them to the existing wires.
Now I gotta learn to solder haha.
Thanks!
To change or not to change them, that is the question Steelerdude1 *General Road Glide Discussions/Pictures 2 07-18-2016 05:41 PM
Saddlemen Cruisn Deluxe Saddlebag Guard Bag Set, anybody use them? SilverGhost Aftermarket Accessories 1 12-03-2012 02:00 AM
Suction cup mount? anyone use them Dmize Equipment-RG 15 07-21-2012 02:04 PM
SMT wheels, Any use of thoughts on them? laxinharley *General Road Glide Discussions/Pictures 15 12-03-2011 12:08 AM
