Speaker Upgrage Options - Road Glide Forums
post #1 of 33 (permalink) Old 02-12-2015, 10:24 AM Thread Starter
Hello,
I considering changing out the speakers in my fairing, for now just the two. I'm not planning on putting on an amp just yet. Eventually I'd like to put 4 speakers in the fairing, get the fairing painted, put the lower speakers in, etc, etc, etc, etc, but I didn't win the powerball last night, so...
I've checked out speakers from hogtunes, hogwired, J&M, and Rockford. I wasn't sure if there was 'other' things out there. Thus far I'm liking the J&M 7.25" speakers as it appears they are improvements even with no amp, AND can handle an amp when I get to the 'wish list'.
So my question is if there is something else I should consider and be aware of?
SquirtRGU is offline
post #2 of 33 (permalink) Old 02-12-2015, 10:39 AM
Just about any speaker is going to be and sound better than stock. There are many other choices besides the ones you listed. Keep reading in the audio forums, best way to decide would be if you can compare by listening.
post #3 of 33 (permalink) Old 02-12-2015, 10:39 AM
Austinslider's Avatar
Im running a set of Biketronics 7.1's in the fairing. They carry a lifetime warranty, they are not cheap but are great speakers. I highly recommend them. You will need to run an amp for these speakers. Running the speakers without an amp will upgrade your sound from stock, but not by much. If your on a budget and you don't mind losing FM, the SS 4.520 ($110) is a great little amp. If you want to run a 2 speaker setup, a lot of people are running a set of Infinity 62.11 and a PBR 300X2 ($150). You don't risk the loss of FM with the PBR. Will also need a set of adaptor rings, which you can find on eBay. Lots of choices out there, make sure you select the right one...
2011 FLTRU VH Power Duals, VH Monster Rounds, SE Heavy Breather, SERT, Bad Dad rear fender, extended bags, PYO 10" Monkey Bars, KW flare, PM Hooligan's (21/18) Bad Dad wrap front fender, PM lowers, Progressive monotubes. Audio: Kenwood X998, SS 4.1000D, Biketronics BT7P1 and BT474(rear pods).
Austinslider is offline
post #4 of 33 (permalink) Old 02-12-2015, 01:40 PM
Orangeappeal's Avatar
I am in theprocess of doing the Infinity Kappa 62.11 and a Fosgate Pbr 300x2. I did hook the speakers up with no amp just to see the sound difference and I do not think you will be disappointed but that is no amp so keep that in mind. Way way better than stock though. Those stock speakers are little crappy china speakers and the magnet is a joke. Good luck!
Orangeappeal is offline
post #5 of 33 (permalink) Old 02-12-2015, 01:54 PM
griswold's Avatar
+1 I hooked up and ran the kappas through the stock head unit with no amp for 2 weeks before I had a chance to hook up the amp (soundstream). However, once you hook up the amp the sound difference is unreal. For what the OP is thinking of spending on a set of J&Ms, he could run the kappas, SS amp, adapters, and all wiring and still probably come out cheaper.
2010 FLTRX, 2003 FXDX, 1983 XLH1000, 1975 FLH
griswold is offline
post #6 of 33 (permalink) Old 02-12-2015, 03:36 PM
shagyluke's Avatar
I have a 15 RGS that I put lower fairing on. I ordered 2 sets of Infinity 62.11I's and a NVX amp from Amazon. I ordered all the wiring harness's from Vtwin and I am under $600.00. My system sounds amazing compared to the stock set up. I just ordered a BT4180 thats going in to replace the NVX for a little more power. Cant wait...
shagyluke is offline
post #7 of 33 (permalink) Old 02-12-2015, 04:07 PM Thread Starter
Thanks for the info, I am looking into the options.
post #8 of 33 (permalink) Old 02-12-2015, 04:07 PM
OP - Do some searching around the various forums and you'll find that this is far and away the most common bang for the buck solution. Great setup for not a lot of cash. Save yourself some time and buy the amp now, ask me how I know.
roadie13 is offline
post #9 of 33 (permalink) Old 02-12-2015, 04:12 PM Thread Starter
Ok, I'll bite. How do you know?
Also: How do the infinity speakers hold up in the elements? I hit rain multiple times throughout the year, and can't always cover the bike when it's parked. (I travel allot). Do they do ok with that?
I guess I should say first, what I'm finding first are automotive speakers. If that's not correct, then the question above is void.
post #10 of 33 (permalink) Old 02-12-2015, 04:52 PM
JM's even bike wash proof, worth the$ and good to go if you upgrade sys
reds4 is offline
Speaker's not fitting. Options? kyle31490 Audio 23 02-20-2015 11:08 AM
Speaker upgrade options - 2015 Glide Sincecrazy Audio 2 01-15-2015 07:35 PM
Speaker choices and options? Help me Skullglide09 Audio 0 05-24-2014 12:50 PM
Speaker Lid Options 911Shark Audio 46 10-07-2013 08:59 PM
Tourpack Speaker Quick Disconnect Options Illiniroads Audio 5 03-06-2012 09:36 PM
