H-Donut's Fosgate Amp Mount - Road Glide Forums
post #1 of 8 (permalink) Old 02-12-2015, 01:16 PM Thread Starter
Orangeappeal's Avatar
Thank you for a perfect fit on my 2011 RGC. I will be installing the second one sometime this week. Waiting for my painter to finish up my Hogtunes lids in Sedona Orange. And may I say the color is spot on. I have see numerous threads about that color. A true professional can get i done. It was not cheap but you all know the saying... You get what you pay for. I will post more pics of the other side and if anyone wants I took pics of the tear down. I a am novice, rookie, wet behind the ears and i did it. Although I havent put it back together so well see how that goes. Good thing I have pictures to reference. I am spending my time doing the stereo upgrade keeping the Harmon Kardon HU. Soldered wires, heatshrink tubing, and so on. Probably not up to par with a professional but at least I can say I did it myself...
Orangeappeal is offline
post #2 of 8 (permalink) Old 02-12-2015, 01:46 PM
Let us know your thoughts on the system once you get it buttoned up.
2012 FLTRX, vivid black
sometimer is offline
post #3 of 8 (permalink) Old 02-19-2015, 08:57 PM Thread Starter
Added. couple more pics. Sounds Awesome! My issue is that the Hogtunes Striker Plate brackets wont stay stuck on where it latches to the bags. For the money I spent and doing it myself I amazed even myself. Well worth the time and effort.
post #4 of 8 (permalink) Old 02-20-2015, 04:13 AM
FlatOut's Avatar
I had the same problem with striker plates, at first I went and bought HD plates to replace but while they were on order I tried this:
Get the thin 3M double sided automotive tape from an auto parts store, heat the striker plate a little bit and install tape to the striker. Then install striker to lid hold for a minute or two then close the lid to the bag, the pressure will clamp the two together. I haven't had an issue since in all weather.
2012 RGC - Work in progress
FlatOut is offline
post #5 of 8 (permalink) Old 02-20-2015, 08:18 AM Thread Starter
Definitely going to get the tape after work today. Thank you!
post #6 of 8 (permalink) Old 02-20-2015, 08:40 AM
OKBigD's Avatar
I ended up just buying some HD strike plates.. No problems with those at all.. I think they were 3$ each, Not much more than a roll of 3M..
OKBigD is offline
post #7 of 8 (permalink) Old 02-20-2015, 09:31 AM Thread Starter
Looks like a common issue. Hogtunes is sending me out a new pair free of charge. But still going to try the tape since that is most convenient for me.
post #8 of 8 (permalink) Old 02-20-2015, 09:54 AM
h-donut's Avatar
thanks for the positive feedback
it's nice to have a a-la-carte system where you pick the pieces and put it together yourself
like when I did my bars, 54 isolated solder joints, then pulled the wires through, inch by inch, but it all worked, 27k miles later, it still wasn't cheap, about $260 for the bars, then another $300 for the magnum shield cables and ring pliers to swap the cable, the wire I used was some hog tunes wire harness, cut to 9" lengths, which I found on ebay for $5 or so
re: rockford, I also like the PEQ dial that the PBR300x2 accepts - it's not perfect but grabbing a dial to boost treble on the fly is easier than surfing through menus, I installed one on each amp, then installed them next to the ACC switch, which powers my GPS for those rare occasions
you have to find the sweet spot for the PEQ to be most effective, again about 55% amp, I switched from a Sony to an Alpine head unit, and I am still messing around with the db gain, which is 18 plus or minus, so far, -6db, -5db, -7db are the front runners
the Alpine seems to press more gain, but that can also backfire with clarity and over run the amps quicker
once finished, every setting you had in the garage seems to go out the window, if a bike had them, versus around town and highway listening, in the end, flatter is better, although the bass is fun, it kills the speakers quicker, treble kills your hearing so.. it's all good, I keep mine just above the 4" exhaust note and work well
it's also good to freshen up the ground, once a year, I let mine go 3 years and had back end corrosion, freshened it up, and the problems went away
I need some hog tunes 6x9 lids in matte, 5x7 CVO lids look good but speaker options are few and far between
2010 FLTRX- r o a d g l i d e
h-donut is offline
rockford fosgate amp mount oldtimer63 Parts for Sale 1 12-18-2017 08:05 AM
h-donut Mods Thread h-donut Road Glide Builds-Document your builds HERE --NEW 57 02-24-2015 12:35 AM
DayMakers with RF amp mounted on H-donut bracket? HogPro *General Road Glide Discussions/Pictures 3 11-21-2013 05:58 PM
Hey h-donut.... SafetyMan *General Road Glide Discussions/Pictures 4 10-16-2010 11:16 PM
