New System being installed tomorrow - Road Glide Forums
post #1 of 18 (permalink) Old 02-23-2015, 07:39 PM Thread Starter
Baggerman's Avatar
Ok, tired of the Harley radio and light just burned out on my 2013 Glide. SO I ordered a system from Cartronics in Bradenton for 520.00 complete and shipped to my door , here's what I got;
Sony Marine MEX 70BT with, Harness and thumb Controller and ASWC-1 so my OEM controls work
Clarion Marine 6.5 Component 300 w speakers with Adapters for Road Glide
Clarion 4Ch 200Watt class D marine micro Amp. This thing is the size of stack of 100 dollar bills. 2 Channel 100W ea. 4channel 50 Watts each 4ohm
Everything is plug and play except one Wire and the guy put in step by step instructions. Ive installed several radios on touring bikes and Amps from Hog tunes, to Hog wired to Bike tronics, Ive used Arc amps, Fosgate amps and to me Amps are all pretty much the same if they have the same output, that being said, Im running two speakers only and just want Blutooth and USB connectivity which it has and will run and drill small hole through left glove box so my phone will charge and play Pandora or my songs. I also have my Library on flash drive I can plug in Front.
I'll let you all know how my budget system works.
Baggerman is offline
post #2 of 18 (permalink) Old 02-23-2015, 07:45 PM
Nordic Berserker's Avatar
Sounds like a good deal, the iPod interface alone from harley is $399. I'd like to know how it works out for you, maybe some pics as well
Nordic Berserker is offline
post #3 of 18 (permalink) Old 02-24-2015, 08:30 AM
UltraNutZ's Avatar
hopefully you also picked up the installation kit needed to fit that radio into the stock HD opening.
2012 FLHTK - VTPBB
UltraNutZ is offline
post #4 of 18 (permalink) Old 02-24-2015, 05:17 PM
toogood8p's Avatar
I just did a similar install... Works awesome
Bear, Prez, Kindred MC
13 FLTRX - Candy Orange - Daymakers, Custom Dynamics - LED turn signals, Kuryakyn Scythe mirrors, Iron Aces bracket, X-grip, floor board extensions, custom sundowner seat, black KW 8", PCV, auto tune, Stage 1 AC, Drago H-pipe, 4" Dragula mufflers.
toogood8p is offline
post #5 of 18 (permalink) Old 02-24-2015, 05:19 PM
toogood8p's Avatar
Photos
post #6 of 18 (permalink) Old 02-25-2015, 06:44 PM Thread Starter
Baggerman's Avatar
t did come with kit. Everything 100% Complete. I can tell you Biketronics should lower their price again because that AWS controller works like a charm and instant. Theres even an APP on the iphone for that Sony Radio. System is really Strong and clear. I set the Amp to low freq and flat. I set radio on custom 250Hrz with +5db of base and it cranks. I ran usb through glove box and sound quality on usb is way better than Blue tooth. Blue tooth enable me to adjust volume on iphone as well but can not on USB I have to adjust it before I plug in. phone calls come through crystal clear and the microphone works perfect. I ran that through other side glove box and pull out and clip on cable to speak. Not bad. USB I'll post pics later but easy install
post #7 of 18 (permalink) Old 02-25-2015, 07:04 PM Thread Starter
Baggerman's Avatar
post #8 of 18 (permalink) Old 02-25-2015, 07:05 PM Thread Starter
Baggerman's Avatar
post #9 of 18 (permalink) Old 02-25-2015, 07:44 PM
UltraNutZ's Avatar
apples to oranges comparison.
BT is the only one on the market that retains AVC.
2012 FLHTK - VTPBB
post #10 of 18 (permalink) Old 02-25-2015, 08:07 PM Thread Starter
Baggerman's Avatar
Apples to Oranges maybe. ASWC-1 can be had for 29-39 dollars and requires one wire to be spliced on later model bikes. Biketronics is 100 % plug and play true , but at $250.00 is cheapest I saw on ebay.
There are a couple on the market Im told but was also told and read several reviews including here that the ASWC-1 is instant and has no delays and is easy to program, and all of this is 100% true. It took no more than 1 minute to program to my Sony head unit and there is no delay. And whats nice is I can choose what buttons work what but I left it how it did it right away.
Not trying to bad mouth Biketronics, but they had the market cornered on this for the last 5 years or more I can remember cause ive bought them before and it was even more then like 350.00. Im just giving my experience and if you wanna save a couple hundred and can cut and solder one Pink wire, then why not.
Dave Mackie 575L cams being installed freedom1974 Engine Related 18 12-15-2017 10:39 PM
255 SE Cams And V&H FP3 Being Installed Swomack Engine Related 63 04-27-2017 03:17 PM
So I installed my new system and have some questions McGarnicle Audio 2 07-12-2014 11:19 AM
New Audio system installed at Laughlin River Run hd4cruzin Audio 17 05-07-2012 01:39 AM
New Sound system installed Sealdoggy Audio 9 01-26-2012 06:49 PM
