P165 Focal speakers in a RG - Road Glide Forums
post #1 of 7 (permalink) Old 03-03-2015, 06:49 PM Thread Starter
DONVITO's Avatar
Has anyone installed these in a newer vintage Roadglide (12 CVO), and did you have any issues with the magnet rubbing the inside of the outer fairing when using Hawg wired adapters?
This is my issue and I can not get the outer fairing set in place correctly, without stressing the plastic and leaving a gap between the in/outer fairing. I have tried rotating the adapters, but it hasn't worked.
I am about to take my adapters to my buddys mill and mill as much thickness as I can get away with and still have adequate support.
Thoughts?
2012 CVO Roadglide Custom in Candy Cobalt/Twilight Blue, and it is almost completely stock. :0)))))
Mods are: Fullsac 1-3/4" baffles, Ohlins 6's (HD357), color matched chopped tour pack. Bluetooth stereo with Arc Audio amp and Focal speakers. On the bucket list; Ohlins drop in fork cartridges and the install of Fuel Moto catless 212 SS headpipe
DONVITO is offline
post #2 of 7 (permalink) Old 03-03-2015, 07:05 PM
I had those same speakers and then upgraded to the K series which have a larger magnet, my speakers barely touch the fairing, but I have Dynamat, I have a FLTRX, but that shouldn't make a difference. Are the adapters flush, and are they authentic Hawgwired and not from eBay?
dbell66253 is online now
post #3 of 7 (permalink) Old 03-03-2015, 07:19 PM Thread Starter
DONVITO's Avatar
Yes the adapters are flush and genuine HW adapters. I doo have the dynamat, but even cut a section out for the magnet clearance. After a short roadtest, there is an obvious wearmark on the inside of the fairing
DONVITO is offline
post #4 of 7 (permalink) Old 03-04-2015, 04:45 AM
BrewCitySinner's Avatar
Can you post a couple pics of the speakers and how they are mounted? Might help in finding a solution.
BrewCitySinner is offline
post #5 of 7 (permalink) Old 03-04-2015, 08:56 PM Thread Starter
DONVITO's Avatar
Ill try and post pics tomorrow. I am having my buddy put the Hawg wired adapters on his mill and take 1/8-3/16" off each side of the adapter to move it closer to the inner fairing. Thanks for the replies, appreciate your input.
DONVITO is offline
post #6 of 7 (permalink) Old 03-06-2015, 06:29 PM Thread Starter
DONVITO's Avatar
Up date, Had 1/8" milled off each side of the adapters and rotated the offset, and there is clearance now and the fairing went on with out any binding. Happy camper here.
DONVITO is offline
post #7 of 7 (permalink) Old 03-06-2015, 07:30 PM
neverdone's Avatar
Good. I had a hell of a time getting mine to fit. Finally got them on.
neverdone is offline
Focal Speakers PolyGlass CVX165 1RADTOY Parts for Sale 0 09-29-2015 06:36 PM
Focal speakers and tweeters hognit Audio 3 06-16-2015 07:40 AM
I added a Focal amp and speakers on my 15 RGS. Where do I get remote power? Major99 Audio 10 03-15-2015 12:50 PM
Looking into a focal amp and speakers Major99 Audio 15 12-18-2014 12:14 AM
Rockford amp and Focal speakers Jims79FLH Audio 5 12-24-2012 11:44 PM
