ipod interface adapter - Road Glide Forums
post #1 of 8 (permalink) Old 03-06-2015, 08:53 PM Thread Starter
BklynRGU's Avatar
I have a hd ipod interface that I was using when I had a iPhone.but now I got a Samsung note 4 and was wondering do they make an adapter were u can plug a female end to the interface cable to a micro usb so you can listen to music off any smartphone.i knoe I can plug it into the 3.5 jack on the radio and also I can still use my old iPhone but my new phone I can store a lot more music then I can on my iPhone.but the whole reason for this is I was wondering can you still use the controls as you would on the iphone
2016 RGS
2011 rgu brillant silver-sold
BklynRGU is offline
post #2 of 8 (permalink) Old 03-06-2015, 11:24 PM
idahointrudr's Avatar
Good question,
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #3 of 8 (permalink) Old 03-07-2015, 06:57 AM
I would say that what you want to do is not possible. I am also a Samsung user and will never go Apple. You will need to deal with the audio cable and no handlebar controls or upgrade the head unit to a model with Bluetooth and that can be adapted to your handlebar controls. I went the Jensen route and it was a very simple clean install and the controls work great for my Samsung phone.
ricerocketroaster is offline
post #4 of 8 (permalink) Old 03-08-2015, 02:11 PM
thedude's Avatar
I can't even find an adapter for the new I phone cable. I can get one that will charge and play but no hand controls.
thedude is offline
post #5 of 8 (permalink) Old 03-08-2015, 05:58 PM Thread Starter
BklynRGU's Avatar
but you would think that HD or even car companies would do something like that.
2016 RGS
BklynRGU is offline
post #6 of 8 (permalink) Old 03-08-2015, 06:48 PM
09Sharknose's Avatar
The Apple 30-pin(iPhone 4) to Lightning (iPhone 5 and up) will work on the HD version iPod interface module. It will charge and allows your thumb controls to work.
As far as 30-pin to whatever Samsung uses( mini usb I think), not sure there's an adapter that will work on the iPod interface module.
09Sharknose is offline
post #7 of 8 (permalink) Old 03-08-2015, 07:22 PM
thedude's Avatar
I did not try the apple addapter because it costs like $50. I tried one of the cheap ones. Now that I know it works I may give it a try but I have been thinking of going to an aftermarket radio.
thedude is offline
post #8 of 8 (permalink) Old 03-08-2015, 07:44 PM
Aftermarket is probably the best route. I eventually changed mine out with an Alpine head unit(149bt) which supports Bluetooth, siriusxm, rear mounted aux, and usb. And it just sounds better and has more tuning options with my amps.
Problem with ipod Nano and/or HD iPod Interface wingman05 Audio 29 09-17-2014 07:48 AM
Replacement iPod cable from Boom Audio iPod interface kit McGruder Audio 7 04-21-2014 05:08 AM
Ipod HD. interface needed if one uses J&M NEW Ipod interface??? hogger Audio 2 10-22-2013 02:28 PM
Harley iPod Adapter fit new iPod pins? Chicago Harley Boy Audio 4 02-06-2013 11:04 PM
Will a Dyna Oil Cooler adapter #26111-05 work on a RG that calls for adapter # 26151- Trikerjon *General Road Glide Discussions/Pictures 1 10-14-2010 07:40 AM
