HELP from the audio gods! - Road Glide Forums
post #1 of 25 (permalink) Old 03-07-2015, 12:01 PM Thread Starter
I am trying to rap up my winter projects as the weather is slowly turning warmer. Down to the radio.
I have a RF PBR300X4 amp and Kicker 4 ohm speakers. I turn the power on and there is very little volume. I have to turn up the volume almost all the way just to hear anything. What did I do wrong. Please understand that I am NOT very good with vehicle audio!
Sweetglide is offline
post #2 of 25 (permalink) Old 03-07-2015, 12:20 PM
Where is the gain set on your amp?
Are you using the stock head unit?
How is the amp connected to the head unit?
2012 Road Glide Custom
Cut, raked and stretched rolling on a 26!
W_D_R is offline
post #3 of 25 (permalink) Old 03-07-2015, 12:21 PM
09Sharknose's Avatar
Check the gain on the amp. Also check all connections to make sure they are 1) good connections and 2) not touching each other somewhere along the wire run.
Do you have a pic of your setup?
09Sharknose is offline
post #4 of 25 (permalink) Old 03-07-2015, 12:47 PM Thread Starter
Connections are good and not touching. They are currently just twisted together for a test run before I soder everything. I adjusted the gain, it's at 5 but the volume increased very little.
post #5 of 25 (permalink) Old 03-07-2015, 12:54 PM Thread Starter
Figured out the volume problem. Now the amp "pops" when I raise the volume. Cool, a new problem!
post #6 of 25 (permalink) Old 03-07-2015, 03:20 PM
What was the problem?
Popping is a sign of a bad ground. Is the Amp grounded at the battery ? It should be.
post #7 of 25 (permalink) Old 03-07-2015, 06:58 PM
neverdone's Avatar
Mind's grounded to the battery and still pops.
neverdone is offline
post #8 of 25 (permalink) Old 03-07-2015, 07:31 PM
BrewCitySinner's Avatar
Running the ground all the way back to the battery is a bad idea. The shorter the run for your ground, the better. Mine is grounded at the triple tree and I don't have any noise, hiss or popping. Just make sure it's clean (no paint) and add a little dielectric grease to keep the connection corrosion free.
BrewCitySinner is offline
post #9 of 25 (permalink) Old 03-07-2015, 07:48 PM
Rockford Fosgate's directions tell you to ground off the battery only.
On a motorcycle, there are no long ground runs.
post #10 of 25 (permalink) Old 03-07-2015, 08:44 PM
h-donut's Avatar
check the input voltage with a meter ( factory speaker outs )
adjust the input voltage level on the amp
the pop could be the input signal crossing that threshold
or the power wire or ground loose at the amp terminal or bonding point
I ground to frame also, rode through a few storms last year, had to freshen that up, it got corroded after three years and was popping at higher volumes
grounding to the battery is a rockford fsb, true
2010 FLTRX- r o a d g l i d e
h-donut is offline
Weather Gods Blessed Me.......Bobber Run SteadyEddie General Off-Topic Discussions 12 03-19-2018 06:32 PM
Aquatic AV-JL Audio HX280/4-Polk Audio MM652s, SMD DD1 rustyj671 Audio 6 08-22-2017 02:49 PM
Wish Me Luck with the gods JacktheBagger General Off-Topic Discussions 8 02-21-2016 07:04 PM
Car audio vs motorcycle audio sdlakerfan79 Audio 20 04-11-2013 06:52 PM
Question for the HK Tech Gods Shrug Audio 13 03-05-2012 12:55 PM
