Sony MEX-M70BT USB drive question - Road Glide Forums
post #1 of 7 (permalink) Old 03-09-2015, 05:40 PM Thread Starter
toogood8p's Avatar
Looking for help... I just installed the MEX-M70BT and I am having a problem getting my USB drive to read properly. Is there a limit on the drive size? Also, I have been trying to use double twist program on the computer to move the music onto the drive. I have tested the USB ports with a much smaller drive and just moved music directly onto the drive and it played, but I want the ability to have playlists. Guess I need to know if there is specifc directory requirements.
Thanks in advance for any help
Bear, Prez, Kindred MC
13 FLTRX - Candy Orange - Daymakers, Custom Dynamics - LED turn signals, Kuryakyn Scythe mirrors, Iron Aces bracket, X-grip, floor board extensions, custom sundowner seat, black KW 8", PCV, auto tune, Stage 1 AC, Drago H-pipe, 4" Dragula mufflers.
toogood8p is offline
post #2 of 7 (permalink) Old 03-09-2015, 06:28 PM
HellInABucket's Avatar
I have the marine sony, and I can tell you that there are limitations on the number of folders, and the number of files per folder.
128 folders, and 500 files/folder is the limitation. If you exceed either of these, it will get funky.
http://www.manualslib.com/manual/437...0.html?page=15
I looked at your manual on line, the only spec they have for USB is max number of files = 10,000.
But - only MP3, WMA, and WAV supported. What kind of files are you trying to play?
Double twist? Whats wrong with.... copy?
2020 FLTRK
Roll away the dew...
HellInABucket is offline
post #3 of 7 (permalink) Old 03-09-2015, 09:09 PM Thread Starter
toogood8p's Avatar
I am using double twist app to move the files so that I have my playlists intact. All of the files are mp3 format.
I think my problem is the drive is too large. I am using a 64 gb 2.0 USB thumb drive. I have a feeling there is a limitation on the size of the drive. I am going to try a 32 gb drive and see if the problem still exists.
post #4 of 7 (permalink) Old 03-10-2015, 04:59 AM
Thats possible, yep.
2020 FLTRK
post #5 of 7 (permalink) Old 03-10-2015, 05:18 AM
jpeesy's Avatar
I have a MEX-GS610BT and use a 64GB and 32 GB, no issues with either. The 64 is plugged into the radio usb jack, the 32 is on the secondary glove box port. I just copy the music, and set to shuffle.
JP
jpeesy is offline
post #6 of 7 (permalink) Old 03-10-2015, 09:02 AM
sprint12's Avatar
Make sure the USB drive is formatted FAT32.
07 Road Glide/SERT/Rinehart True Duals/Ness Big Sucker/CR 575 Cams/C&C FastBack Seat/HogPro Indy/Biketronics Audio
sprint12 is offline
post #7 of 7 (permalink) Old 03-10-2015, 11:34 AM Thread Starter
toogood8p's Avatar
It was formatted for FAT 32.
Jpeesy - have you tried the 64 gb on the rear USB port?
Sony MEX-XB100BT Head unit Dirigo74 Audio 3 05-10-2016 09:03 PM
Sony MEX-XB100BT RedneckMedic66 Audio 0 08-25-2015 01:41 AM
Sony M70BT AVC not working tidd130 Audio 2 05-13-2015 08:45 AM
Sony MEX-M70BT head unit JKRSDETROIT Parts for Sale 5 12-23-2014 12:44 PM
Sony MEX-BT3000P ftb2ss Audio 0 06-18-2013 11:55 AM
