I added a Focal amp and speakers on my 15 RGS. Where do I get remote power? - Road Glide Forums
post #1 of 11 (permalink) Old 03-13-2015, 04:59 PM Thread Starter
So I got it all installed and the radio flashed. Left the dealer and he thought he popped the fuse but in reality, it had no remote power. I'm sure it's an easy fix just looking to see where to get power.
On the plus side, they didn't charge me for the flash because they couldn't get any sound.
Never marry an ugly woman, it just takes the energy right out of you.
Major99 is offline
post #2 of 11 (permalink) Old 03-13-2015, 05:02 PM
Ohiobellboy's Avatar
I was going to mention the orange white wire off the headlight harness until I realized you have a '15. I don't know if that wire is still there on the new ones and if you can use it because of the can-bus wiring.
A.K.A OBB
Ohiobellboy is offline
post #3 of 11 (permalink) Old 03-13-2015, 05:13 PM Thread Starter
My buddy suggested the power outlet for switched power.
Major99 is offline
post #4 of 11 (permalink) Old 03-13-2015, 05:33 PM
That sounds feasible. The remote turn on for the amp shouldn't be much of a draw and the power outlet is amped higher than it was for the cigar lighter they did away with.
A.K.A OBB
post #5 of 11 (permalink) Old 03-13-2015, 05:35 PM
OneSlickGlide's Avatar
Agreed. Just get a Manual and tap into a switched power wire. Good to go then.
OneSlickGlide is offline
post #6 of 11 (permalink) Old 03-13-2015, 10:24 PM
shagyluke's Avatar
I used the one from Vtwin on my 15 RGS.
http://www.vtwinaudio.com/store/prod...ire-connector/
Takes thirty seconds to plug in.
shagyluke is offline
post #7 of 11 (permalink) Old 03-14-2015, 03:25 PM
danfor's Avatar
I just attached it to the purple wire with blue stripe going to the 12V outlet on the lef side of the fairing.
2015 Road Glide Special in denim black, 4" Rinehart true duals, Thunder Max tuner, Arlen Ness Deep Cut air cleaner & grips, 4.5" extended saddlebags, rear fender extension, 12" KST apes, Focal Focal KRC & AC speakers, Arc Audio Moto 600.4 amp, custom pin striping, Kuryakyn horn cover, over 40 powder coated parts and counting. More to come!
danfor is offline
post #8 of 11 (permalink) Old 03-14-2015, 03:41 PM Thread Starter
Where is the plug? Is it near the turn signal connector?
Major99 is offline
post #9 of 11 (permalink) Old 03-14-2015, 06:09 PM
shagyluke's Avatar
If you have your fairing off and standing looking at it from the front its in the top left. Here is a picture you can see that I ran the blue wire under the head unit and straight to the amp.
post #10 of 11 (permalink) Old 03-15-2015, 12:40 PM
maddmoe's Avatar
You see that pic above with the front fairing off well there are plugs on both sides , if your standing in front of the bike you see the one on the left side has nothing plug into it next to the yellow tape on the other cable, the one on the right side has a plug in it thats for the power outlet next to the pocket on the other side of the front fairing. These plugs are for your accessories & only power up when your bike is turned on.
Dont talk about it, Be about it !!!
maddmoe is offline
I want a remote start and remote control over my air ride? dshudson *General Road Glide Discussions/Pictures 17 08-30-2017 02:26 PM
Added amp and speaker s to my 2015 RGS Shovelryder New Members Welcome Area 9 02-16-2016 07:39 PM
Looking into a focal amp and speakers Major99 Audio 15 12-18-2014 12:14 AM
Rockford amp and Focal speakers Jims79FLH Audio 5 12-24-2012 11:44 PM
After you install J&M or other speakers, what do you do with the factory speakers? Black09inOK Do-IT-Yourself 6 10-01-2010 01:53 AM
