2015 RGS Amp install - Road Glide Forums
post #1 of 8 (permalink) Old 03-14-2015, 12:58 PM Thread Starter
Is there enough room behind the headlight assembly to install the RF PBR300x4 amp? Does anyone have an alternate installation space?
blazeman is offline
post #2 of 8 (permalink) Old 03-14-2015, 02:22 PM
I installed a Focal FD4-350 amp under the head unit on my 15 special. I'm not sure of the dimensions of the PBR but I'm sure a quick google search would give you the dimensions to compare. .
Good luck. Don't forget to get the radio flashed.
Never marry an ugly woman, it just takes the energy right out of you.
Major99 is offline
post #3 of 8 (permalink) Old 03-14-2015, 06:16 PM
shagyluke's Avatar
There is not really any room behind the head light assembly, There is however a lot of room under the head unit. Thats where I installed my Bike Tronics 4180 amp. You can check it out here.. http://harleytechtalk.org/htt/index....c,80359.0.html
Good luck and remember to get your radio flashed..
shagyluke is offline
post #4 of 8 (permalink) Old 03-17-2015, 09:52 AM
dirtracin23's Avatar
Behind the headlight assembly and under the head unit are pretty much one in the same.
dirtracin23 is offline
post #5 of 8 (permalink) Old 03-17-2015, 07:17 PM
ynotbmester's Avatar
Send a message via Yahoo to ynotbmester
Jumping in here - (sorry for bad pics)
running ( one Hawg wired amp 2 channel)
1) I unbolted the "boom speaker pod" ( R SIDE FACING FRONT OF THE BIKE)(5 screws I think) there was a lot of room under the black shelf bracket (on both sides L&R of the radio) - used velcro attached the amp on the shelf-
2) bolted back up the speaker pod, amp fits perfect as if that space was made for it - adjustments are easy as well in that location - and the bike looks like it came - (leaving room for more upgrades)
3) as said before there is the exact same room on the other side for another amp of the same size-
4) I velcroed to the roof inside the "boom speaker pod" - the JL Audio C5-650x L & R separate adjustable crossovers behind each speaker
5) Also taped the boom box pod for a tighter sound - some air was escaping
- no problems
ynotbmester is offline
post #6 of 8 (permalink) Old 03-22-2015, 10:48 PM Thread Starter
Ended up using shagyluke's suggestion. Thanks for all the useful information. Ready for some saddlebag speakers and lowers.
blazeman is offline
post #7 of 8 (permalink) Old 03-22-2015, 11:51 PM
JMJOHN
JMJOHN's Avatar
decent video on that very subject here https://www.youtube.com/watch?v=8a0p6IF2hS8 ,,,,,,
JMJOHN is offline
post #8 of 8 (permalink) Old 03-22-2015, 11:55 PM
torqu's Avatar
Nice comparison vide JMJOHN. Sounds great .
torqu is offline
Help with Daymaker Foglight install on 2015 RGS Dead Bird Dog Lighting 24 03-10-2018 02:01 PM
Help- No throttle at all after bar install on 2015 RGS hatzo1 Controls & Handlebars 6 05-28-2016 10:18 AM
2015 RGS Amp install Help... EvilTwinATX Audio 4 03-07-2016 07:29 PM
Amp install 2015 RGS Shaner87 Audio 13 10-19-2015 07:07 PM
Any info for Soundstream install on a 2015 RGS SJA66 Audio 10 08-20-2015 09:23 AM
