Audio help - Road Glide Forums
post #1 of 6 (permalink) Old 03-17-2015, 05:12 PM Thread Starter
sj01fltri's Avatar
Audio help
Ok i upgraded to a Hog Tunes Amp and Speakers,using a Sony model GS610BT radio,when i crank up the volume over 18 or 20 the outer fairing starts to vibrate also the inner,would dyna mat or some type of sound deadening material help deaden this also does any one make cones for the speakers to stop this,not changing amps or speakers,any ideas.
sj01fltri is offline
post #2 of 6 (permalink) Old 03-17-2015, 05:37 PM
I've been using Dynamat for a while, if you have strong bass, you're going to have some vibration, but I believe it does help, using cones with Dynamat didn't seem to make much more difference IMO.
post #3 of 6 (permalink) Old 03-17-2015, 05:47 PM
Turn down the bass.
Big_gary is online now
post #4 of 6 (permalink) Old 03-17-2015, 06:32 PM Thread Starter
sj01fltri's Avatar
Well as soon as i can figure out how have yet to find a setting for treble or bass,do they call it something else now a days.
post #5 of 6 (permalink) Old 03-17-2015, 06:57 PM
09Sharknose's Avatar
If your head unit has an eq setting, the markers on the left are bass.
09Sharknose is offline
post #6 of 6 (permalink) Old 03-17-2015, 07:08 PM
I know how you feel. My Alpine came with a 50 + page user manual.
Aquatic AV-JL Audio HX280/4-Polk Audio MM652s, SMD DD1 rustyj671 Audio 6 08-22-2017 02:49 PM
Car audio vs motorcycle audio sdlakerfan79 Audio 20 04-11-2013 06:52 PM
Arc Audio Speaker Adapter Install Help PC PaiN Audio 9 11-28-2011 05:22 PM
Audio help jimmyray11349 Audio 8 11-06-2011 08:15 PM
Audio help> JOHN103 Troubleshooting for Road Glides 4 05-29-2010 08:00 PM
