pbr 300x2 setup - Road Glide Forums
post #1 of 8 (permalink) Old 03-19-2015, 04:39 PM Thread Starter
pbr 300x2 setup
getting ready to install a RF 300x2 amp and would like some advice with the setup. Im not sure what settings to use for the variable cross over 50HZ to 500HZ and which position the crossover switch should be set to HP ,AP , or LP. I plan on setting the gain to 5 and will be using kappa 62 11i speakers. Thanks
raker is offline
post #2 of 8 (permalink) Old 03-19-2015, 04:49 PM
09Sharknose's Avatar
Hp-high pass(only freqs above the cutoff freq will be heard)
Lo-low pass(only freqs below the cutoff freq will be heard)
Ap- all pass(all freqs will be heard) unless there is a manual freq control knob.
I assume you mean that you plan to set your gain at 5 as a start point when you begin tuning. All speaker/amp combos are different so you'll want to do some sound testing before deciding on a setting for the gain.
For a BASIC gain tune, start your gain at zero. Turn the volume on your head unit to about 75% of max. Then adjust your gain until you hear distortion in your music, then turn down the gain just a bit until the distortion is no longer audible. Take your neighbors a beer.
09Sharknose is offline
post #3 of 8 (permalink) Old 03-19-2015, 04:49 PM
Had mine on all pass and the gain was on 4.5. Same speakers . Sounded great while it lasted.
post #4 of 8 (permalink) Old 03-19-2015, 05:02 PM Thread Starter
thanks for the quick replies, any ideas on setting the FREQ. dial? it has a range of 50 to 500 HZ.
raker is offline
post #5 of 8 (permalink) Old 03-19-2015, 06:23 PM
Look at the freq range on the speaker specs. Set it at whatever your speakers will handle.
post #6 of 8 (permalink) Old 03-19-2015, 06:34 PM
h-donut's Avatar
set the dial at about 80Hz with HP selected and gain at about 5.5
that will remove the lower stuff, and allow your speakers to moved easier, more movement, more sound
last time I tuned the crossover I did it by looking at cone movement
then fine tuned by ear
played with the HU EQ and ultimately brought the gain down a bit
if you run AP, speakers have to work too hard
those 60Hz notes were designed for stadium 15's and 18's
you also double or reinforce the crossover settings at the same point if your head unit has that capability
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #7 of 8 (permalink) Old 03-19-2015, 06:51 PM Thread Starter
thanks for the help. Its been 30 years since I have installed a stereo. h-donut, nice job on the amp mount and fast shipping
raker is offline
post #8 of 8 (permalink) Old 03-19-2015, 07:22 PM
h-donut's Avatar
I have mine set at about 127Hz and 48% gain
run the 120HP setting in my Alpine menu - with a -5db - for gain
so mine is set fairly high, but it help me get more mid bass, etc...
h-donut is offline
Rokker XTs with PBR 300x2 & Ipod interface gfyoung3 Audio 6 04-21-2013 11:44 AM
WTB - RF PBR 300x2 Mounting Bracket outlawjessejames Wanted! (Buy or Trade) 5 03-23-2013 04:02 PM
Alpine PDX F6 or 2 Rockford PBR 300X2's yamahoe72 Audio 3 03-11-2013 11:08 PM
RF PBR 300X2 / Biketronics's Titan II JadaGlide Audio 5 08-31-2012 11:25 AM
Some RG mods including PBR-300x2 Amp install mrwatson Audio 14 04-09-2012 05:37 PM
