Help before I drive myself mental - Road Glide Forums
post #1 of 5 (permalink) Old 03-19-2015, 05:41 PM Thread Starter
buddy75's Avatar
Ok guys been working on installing a amp on a 2015 , clarion amp. Everything went well at first. Speakers into amp out on the other. Grounded amp to frame, another wire to battery and than tied into accessory plug for switched power. Put it all back together and worked like a charm..... Than the problem started, I try to start the bike no go. Just click click click... I was thinking I must have tripped the security somehow. Than was playing with the radio listen to it setting bass etc and than the sound goes dead. All functions still work no sound. Than I take it all apart , still power to amp , fuse is good. Bike battered is pretty much dead so I am charging that now. But what gives? Did I screw up somewhere I can't figure it out... No start no music. Please help me ...lol I am going nuts and ready to kill myself for screwing with this new bike
buddy75 is offline
post #2 of 5 (permalink) Old 03-19-2015, 05:50 PM
Sounds like you just killed the battery.
post #3 of 5 (permalink) Old 03-19-2015, 06:06 PM Thread Starter
buddy75's Avatar
Little update. Just went all through it again. Music is back on, it must kill the speakers when the battery is low evades the screen lite up if that makes any sense. I also noticed when I trun it on it says enter pin but than goes away almost instantly. No idea how to do that. Also when discounting the battery trip the security? I thought as long as I had the key pod always close it wouldn't trip. When the security trips does it cause the bike just to click?
buddy75 is offline
post #4 of 5 (permalink) Old 03-19-2015, 06:26 PM
No, the bike's engine/starter won't make a sound when security is activated. Its discontinued from the power via the security. Charge the battery up overnight and you should be good , unless you have a bad battery.
post #5 of 5 (permalink) Old 03-19-2015, 06:38 PM Thread Starter
buddy75's Avatar
Rock thanks guys. Hoping that's all it is, wonder if there is anything that I could have done that would be draining the battery. Meaning with the install? I know how I killed it this time by screwing with it so much....is it possible to wire it up somehow that would drain the battery?
buddy75 is offline
S&S cam drive vs the new HD cam drive kit jprider4life Engine Related 4 09-04-2015 07:17 AM
Mental Therapy Ride Mischief Road Trip Discussions/Stories/Pictures 4 06-27-2014 01:33 PM
some help with a mental problem evilmonkey *General Road Glide Discussions/Pictures 33 05-30-2014 02:15 PM
Mental Cases staush General Off-Topic Discussions 5 12-14-2012 08:06 PM
Allow myself to introduce..........myself Lifetimelifter New Members Welcome Area 46 04-01-2012 10:23 AM
