Can somebody explain (dumb down) RMS power to me? - Road Glide Forums
post #1 of 5 (permalink) Old 03-22-2015, 10:17 PM Thread Starter
steel breeze's Avatar
If I'm correct, RMS power is the average continuous power used. And peak is just that. But, my question is this. I see some speakers that advertise 6-60RMS, and some others that advertise 15-100RMS. Just wondering what the difference is. Thanks!
2005 Shark. Madstad shield, Progressive Mono tubes, Kenwood KMR-M315 deck, Alpine SPR-60C speakers, Trask V-line bars, V&H Pro Pipe, S&S cams, 21" Fat Spoke, extended bags, SE air cleaner.
steel breeze is offline
post #2 of 5 (permalink) Old 03-22-2015, 10:33 PM
chromedome's Avatar
RMS stands for Root Mean Squared and is equal to .707 times the peak power.
So a speaker that is rated at say 70 watts rms would handle a peak of 100 watts.
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
post #3 of 5 (permalink) Old 03-22-2015, 10:36 PM Thread Starter
The higher the RMS the better right?
post #4 of 5 (permalink) Old 03-22-2015, 10:44 PM
chromedome's Avatar
Maybe, the Higher the rms sometimes mean the less efficient the speaker. In other words it can handle lots of power but it might just dissipate the higher power as heat instead of sound. You want the most efficient speaker you can find that is rated in dB per 1 watt. If it also has a high rms rating that would give you the most volume. That means you could run reasonable amounts of power, get higher sound levels and have less chance of blowing the speakers.
post #5 of 5 (permalink) Old 03-22-2015, 10:58 PM Thread Starter
I think I'm following you on this. Thanks! I'm running some Polk DX1651's right now, but have been considering pulling the trigger on some Kappa's or some more Polks. The MM651UM's. I've heard good things about both of those. An amp is in the future as well.
Can Someone Explain Ohms To Me? The Volusianator Audio 15 06-20-2018 11:25 AM
can anyone explain CVO TBW 13HDGLIDE Controls & Handlebars 12 01-26-2013 08:27 AM
Somebody stop me!! Howardsternspenis *General Road Glide Discussions/Pictures 6 01-05-2013 04:34 PM
Can some one please explain this HDMARK *General Road Glide Discussions/Pictures 1 02-09-2012 06:44 PM
Somebody take the paint can away Hotroadking Do-IT-Yourself 8 03-06-2011 07:56 AM
