PBR300 X2 or X4? - Road Glide Forums
post #1 of 7 (permalink) Old 03-23-2015, 03:32 AM Thread Starter
PBR300 X2 or X4?
I've decided on the components I want to use, but I need advise on whether to run two or four speakers on my 2009. I'm going to use Infinity Kappa 62.11i's and a PBR300. I would add pods and speakers to my lowers later on, if there was a huge difference in sound, but the bad thing is that I may or may not want the lowers on in the summer. Peak riding season. For those of you running these set ups, is there enough difference in sound to run four speakers? Thanks...
Mudslide is offline
post #2 of 7 (permalink) Old 03-23-2015, 04:26 AM
stripclub's Avatar
Oh yea, 4 is a unbelievable difference, I am running 8 Infinity Kappas, and 2 soundstream amps. You will be amazed in the difference going from 2 to 4 speakers will do for you.
stripclub is offline
post #3 of 7 (permalink) Old 03-23-2015, 05:15 AM Thread Starter
That's what I was thinking. Just didn't know if 4 at 75w each would be much better than 2 at 150w each. If so, I could get the 4 channel amp and expand later.
Anyone else?
Mudslide is offline
post #4 of 7 (permalink) Old 03-23-2015, 06:42 AM
bless0's Avatar
The PBR300x4 amp is strictly for 4ohm speakers only keep that in mind.
bless0 is offline
post #5 of 7 (permalink) Old 03-23-2015, 03:49 PM
h-donut's Avatar
PBR300x2 is a better amp
does 2ohm, and has a better adjustment on the crossover, plus a PEQ dial option
I have 4 speakers ( 4ohm - wired to parallel - 2ohm ) on the front amp
2 on the other amp
more speeakers helps - because is has to be a little over the top on a bike to hear it clearly - and makes more efficient use of the power
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #6 of 7 (permalink) Old 03-23-2015, 04:27 PM
The 300x2 is the better amp IMO, and I've had both. Also the Infinity's are 2ohm speakers so the 300x2 would be the obvious choice, it would be wise to run an additional amp if you're going to add more speakers.
post #7 of 7 (permalink) Old 03-23-2015, 08:22 PM Thread Starter
Thanks for the replies. X2 it is! I might add speakers later, but it will be a while.
Mudslide is offline
PBR 300 x2 install in 4.3 radio HDFFR Audio 5 01-20-2016 08:27 AM
Antenna X2 OR? egiles Audio 0 10-26-2013 06:48 PM
fresh install, 2 x pbr300, 4 x mm651 W_D_R Audio 9 12-17-2012 10:02 PM
Iron butt x2 glide69 Road Trip Discussions/Stories/Pictures 1 07-21-2012 01:19 PM
Arc 125.2BX vs RF PBR300 InMotionJosh Audio 3 11-09-2011 03:24 PM
