Speakers cutting in/out while riding - Road Glide Forums
post #1 of 6 (permalink) Old 03-28-2015, 11:56 AM Thread Starter
SemperGlide13's Avatar
So two years ago i upgraded to boom audio amp and speakers. While bike is sitting there i can turn them all the way up and everything is fine. While riding i can only go to half volume before they start cutting in and out. Kinda sounds like a cd skipping. Am i just pushing them to hard? Doesn't make since to me if they work fine at idle. If someone has had this problem please let me know.
SemperGlide13 is offline
post #2 of 6 (permalink) Old 03-28-2015, 02:09 PM
My RF PBR 300 X2 did the same thing. Replaced the amp and all is good.
post #3 of 6 (permalink) Old 03-28-2015, 05:11 PM Thread Starter
Is there a amp that is just plug and play, that would replace the harley one?
post #4 of 6 (permalink) Old 03-28-2015, 06:45 PM
sfcusaret2004's Avatar
Sounds like amp clipping. If you watch the you tube video from Paul yaffee and Rockford fosgate, they describe how to setup the amp one you install it. One of the things they mentioned it's to turn the the AVM all the way off. If it is on it will cause the amp to"clip" our shut down just like you describe. Try cycling through your audio program until you get to the AVP(AVM) then turn it all the way off and see if it still does this when riding.
sfcusaret2004 is offline
post #5 of 6 (permalink) Old 03-28-2015, 08:29 PM
I always left the avc on, I like the convenience. I tried turning it off once trouble started but it didn't help me. My pbr 300x2 worked flawless for 6 months until a 4 hr ride on a 98 degree day 80 % humidity. Thats what killed it , I believe.
post #6 of 6 (permalink) Old 03-28-2015, 08:33 PM
There are a few companies that make plug & play amps such as J&M. There is a used J&M amp in the parts 4 sale section now.
2016 replacement speakers Infinity Kappa 62.11I No Cutting Factory Wires pairman007 New Members Welcome Area 2 07-23-2018 07:21 PM
2000 RG cutting off while riding then cuts back on Lamar619 Troubleshooting for Road Glides 1 08-05-2015 10:59 AM
speakers cutting in and out sloride Audio 7 05-19-2013 03:11 PM
Saw this while I was out riding today.. Chicago Harley Boy *General Road Glide Discussions/Pictures 22 02-10-2013 09:03 PM
HD Head Unit cutting out watsondog Audio 14 04-20-2012 09:33 AM
