Soundstream amp set up - Road Glide Forums
post #1 of 8 (permalink) Old 03-29-2015, 09:44 AM Thread Starter
Soundstream amp question
if i use the hi input on Soundstream PN4 520 amp coming from the stock 2005 HU will I have to find a wire for the remote on or should it turn on o and off without?
Any experience on this
TheRef73 is offline
post #2 of 8 (permalink) Old 03-29-2015, 10:01 AM
OneSlickGlide's Avatar
I believe you still need to hook up the remote wire to turn the amp on.
OneSlickGlide is offline
post #3 of 8 (permalink) Old 03-29-2015, 01:00 PM
indytrucks's Avatar
Yes, you will need a remote wire hooked up.
indytrucks is offline
post #4 of 8 (permalink) Old 04-04-2015, 01:01 AM Thread Starter
Amp questions again
it is my understanding if the hi in speakers are used as connector that will power up the amp.
looking for someone that has installed the Soundstream p4 520 model to confirm. I am more concerned that it auto shuts off so as not to drain the battery.
And what do you use to fasten in fairing. will it fit on top of radio?
TheRef73 is offline
post #5 of 8 (permalink) Old 04-06-2015, 03:44 PM
It will not fit on top of the radio. I put mine on the right side between the inner fairing and glove box and used hook and loop tape to hold it. As for the remote wire I hooked it into the lighter
Jonathanje is offline
post #6 of 8 (permalink) Old 04-08-2015, 08:26 PM
ScreamingSkulls's Avatar
No remote is needed if using hi input. I installed both mine in rear saddlebags. Wanted access to them and didn't like the position in the front fairing.
ScreamingSkulls is offline
post #7 of 8 (permalink) Old 04-09-2015, 07:21 AM
love the conflicting information
2012 Road Glide Ultra
79HP 103 TQ, tuned by Ed at The Dyno Difference.
tsigwing is offline
post #8 of 8 (permalink) Old 04-09-2015, 08:01 AM
griswold's Avatar
I ran my soundstream off the hi input before adding a new radio. I did not use the ground in the center of the high input lines (just the + - ). I ran a remote wire from the extra wire on the head light harness covered by the red cover. Was it needed? I dont know? It takes a minute to run and every other system I have installed previously needed a remote wire.
2010 FLTRX, 2003 FXDX, 1983 XLH1000, 1975 FLH
griswold is offline
Soundstream AMP & Magic Box SJA66 Parts for Sale 2 02-08-2017 06:15 PM
AMP mounts for Soundstream PN4.520d Jims79FLH Parts for Sale 3 10-01-2014 03:46 PM
mounting bracket for soundstream amp Thaddieus Audio 48 01-26-2014 06:27 PM
Soundstream amp install pic/questions Beavz Audio 11 01-12-2013 12:13 PM
My stereo, Soundstream amp and speakers ddaarr Audio 4 05-12-2011 08:26 PM
