Mixing impedance - Road Glide Forums
post #1 of 3 (permalink) Old 03-29-2015, 08:00 PM Thread Starter
dmiller's Avatar
Mixing impedance
Forgive me if this has been addressed. I made a mistake and got two sets of polk speakers for my fairing, one set being 2 ohm and the other being 4. I have not ordered the amp but was planning on using the rf pbr300x2 to power them. Is it ok to mix impedance and how should I wire them? Will this amp work for me? Thanks in advance for any advice.
dmiller is offline
post #2 of 3 (permalink) Old 03-30-2015, 08:44 AM Thread Starter
dmiller's Avatar
So wiring in series gives me a 12 ohm load and parallel gives a .66 ohm load. Will the 12 ohm load noticeably affect the quality of sound?
dmiller is offline
post #3 of 3 (permalink) Old 03-30-2015, 10:19 AM
wiring in series will give a 6 ohm load, not 12, and yes it will decrease the available power to the speakers. Usually not a good idea to wire to different speakers together as you will not be able to balance out the sound at all. If your going to do this, either get 4 2 ohm and series them, or 4 4 ohm and parallel them (if your amp is 2 ohm stable).
2012 Road Glide Ultra
79HP 103 TQ, tuned by Ed at The Dyno Difference.
tsigwing is offline
mixing speakers BubbaBeef Audio 11 02-05-2018 12:26 PM
Mixing and matching performance parts Road dawg Tech Area 10 03-27-2016 10:00 AM
Mixing Speakers sometimer Audio 2 02-22-2016 01:10 PM
Harley mixing standard and metric too cyclotron *General Road Glide Discussions/Pictures 10 02-27-2011 03:44 PM
