Where do you mount your amp? - Road Glide Forums
post #1 of 8 (permalink) Old 04-07-2015, 09:25 AM Thread Starter
sharknose10's Avatar
I need some advice!! I have a 2010 RGC with a set of Focals in the stock location and I am wanting to add a set of inner fairing speakers. I have an Arc 125.4 mini inside the fairing between the right glove box and inner fairing. My question is where can I mount this amp so I can install a set of inner fairing speakers? Any pics or advice would be greatly appreciated. Thank you!!
2010 RGC, 21/17 Wanaryd, Top Shop bags, fender,side covers, Dragula 2, Ness Legs, PM mirrors, SE heavy breather, Alpine 149BT, 4 Hertz 165.1, Hertz ST 25, CVO lids with Hertz 6x9ís, powered by Micro 4 amps, Battistinis boards, Vindikta 12" bars.
sharknose10 is offline
post #2 of 8 (permalink) Old 04-07-2015, 01:53 PM
Amplifier mounting
I tried mounting a smaller amp away from the boxes and it interfered with installing the outer fairing. best option if you really want fairing speakers there is to mount the amp in a saddlebag and give up some storage. I ended up forsaking the second set in the fairing due to cramped quarters. I will eventually get a set of saddlebag lid speakers if needed...
2013 Road Glide Custom Pearl Orange 7-13-2013
cvanmete is offline
post #3 of 8 (permalink) Old 04-07-2015, 03:29 PM
Will you amp fit on top of the radio? Personally I use Hawgwired amps because I can have 4 amps in the fairing with no problem. If the amp will not fit on top of the radio, the bags may be your next option.
post #4 of 8 (permalink) Old 04-07-2015, 06:28 PM
Deadstroke's Avatar
I mounted mine on the side of the radio.. Inner fairing speakers dont do much so I will now just run the amps on the inside.
Deadstroke is offline
post #5 of 8 (permalink) Old 04-07-2015, 07:30 PM
What were you using for inner fairing speakers?
post #6 of 8 (permalink) Old 04-07-2015, 07:55 PM
MightyWhitey's Avatar
I think it would be more accurate to say they didn't do much for you. Made a big difference for me. From one set of Polk MM6501 to adding a second set of MM651's in the inner was a big difference. For the OP I put my amp behind the media player I replaced the factory deck with. It's a little soundstream. Works well for me.
MightyWhitey is offline
post #7 of 8 (permalink) Old 04-08-2015, 04:33 AM
Amplifier mounting
https://www.roadglide.org/showthread.php?t=23958&page=2
check out that maybe work for you..
cvanmete is offline
post #8 of 8 (permalink) Old 04-08-2015, 09:06 AM
Deadstroke's Avatar
I have was using focals and polks.. They cancel each other out facing each other and it doesnt do much for the performance just like adding subs to a bike. If you are in a parking lot then you are good.. Much better to use that space for amps.
To each their own though if you like them then you do..
If you're running an amp, what did you do for an antenna? anonymous_1 Audio 17 08-31-2016 01:11 PM
Where/how did you hide or mount your strobe & stablizer boxes? hometoast Lighting 5 03-23-2015 02:36 PM
EZ Pass - Where do you mount it on your Road Glide? OrgTRX Road Trip Discussions/Stories/Pictures 18 07-08-2014 02:41 PM
Do you think I can mount this amp inside my fiaring? sdlakerfan79 Audio 6 03-22-2013 02:42 PM
After you install J&M or other speakers, what do you do with the factory speakers? Black09inOK Do-IT-Yourself 6 10-01-2010 01:53 AM
