2015 RGS- Audio Upgrade - Road Glide Forums
post #1 of 6 (permalink) Old 04-12-2015, 05:35 PM Thread Starter
DarkKnight15's Avatar
I have a '15 Road Glide Special, I purchased RF PBR 300x2, and Hertz 6.5 HCX 165. I am only doing front fair speakers and amp. Has anyone installed the Hertz, I pulled the stock speaker and tried to fit Hertz in to see if it was an easy perfect fit, its not, The magnet on the Hertz is way bigger and hits the inside of the front fairing. Wondering if anyone has installed them and what the did to make them fit. Grind out the inside w a dremel ? Fab a ring to sit above stock placement ? Also anyone with the infinity Kappas, did you have this problem, or do they fit in the stock speaker housing ? not looking to return the Hertz, if its not too crazy to get them to fit, but not going to sacrifice quality of Hertz or Infinitys for a lower quality speaker plug and play. Any advice on how you have done this install would be greatly appreciated. Thanks!!
DarkKnight15 is offline
post #2 of 6 (permalink) Old 04-13-2015, 06:13 AM
I just installed the infinity kappa 62.11i's and a soundstream amp this weekend. Speakers fit fine. I've seen where some have had an issue with the speaker grills but mine fit with no problem.
mtgbkr200 is offline
post #3 of 6 (permalink) Old 04-13-2015, 04:17 PM Thread Starter
No modifications at all, the 6.5 Infinity's bolt right in ? no adapter rings, nothing ? No matter how I try these Hertz hit the inside of the Fairing, not sure I want to go grinding out random plastic vs returning the Hertz for the Infinity. Thank you
post #4 of 6 (permalink) Old 04-13-2015, 05:33 PM
My JL C3 650's fit no problem, no mods!
'15 FLTRXS, Rush duals, RCX slip ons,,,,,,,
TVH475 is offline
post #5 of 6 (permalink) Old 04-13-2015, 06:30 PM Thread Starter
Mounted the crossovers inside fairing and tweeter on the speaker ?
post #6 of 6 (permalink) Old 04-13-2015, 08:03 PM
I wrapped the x-over in polyfil put them in the speaker enclosure & yes the tweeter mounted to the mid!
TVH475 is offline
Audio upgrade 2015 CVO ultra ledwards Audio 3 04-04-2018 08:39 PM
2015 RGS fairing speaker upgrade.. NETacoma98422 *General Road Glide Discussions/Pictures 29 06-16-2016 10:25 PM
2015 Road Glide Audio Upgrade Issue thedarkness Audio 0 05-02-2016 10:40 AM
2015 RGS audio upgrade Shaner87 Audio 37 10-06-2015 08:16 PM
2015 RGS audio decision!!! DWILPAT Audio 14 07-04-2015 10:22 PM
