Radio gremlins - Road Glide Forums
post #1 of 4 (permalink) Old 04-13-2015, 07:51 AM Thread Starter
Lucky D's Avatar
Radio gremlins
Howdy all,
A Public Service Announcement from Lucky D
My Alpine 149 BT / Fosgate PBR had a weird little problem. All at once I had no sound. All radio functions worked ... You could see it on the display of the head unit, the amp was working ( fan, power light were on ) but no sound outta the Polk MM 651 speakers. None. Not even a hiss.
Long story short, the amp was grounded to one of the inner fairing bolts and over the course of the last 12 months since it was all installed, that ground point ceased to be a solid ground ( even though the paint had been scraped off and the ring terminal on the ground wire was solid and the nut was torqued to specs.) I tried moving the ground wire to one of the other 3 bolts and still no luck.
Ran a 10 gauge wire from the negitive battery terminal and all's well.
So just in case you ever have weird electrical issues ....
This concludes this Public Service Announcement
... Chrome?? We donneeedno stiinnkinng chrome.
Lucky D is offline
post #2 of 4 (permalink) Old 04-13-2015, 08:18 AM
I just recently went with an aftermarket radio, amp and speakers lids. On the advise of other members I grounded at the battery. Pulling the tank is very simple so I ran everything in the plastic channel under the tank with all the other factory wires. Grounding at the bracket was very enticing but decided against it because of issues like yours and I really didn't want to keep going in the fairing
post #3 of 4 (permalink) Old 04-13-2015, 09:50 AM
OKBigD's Avatar
I also ran a ground wire from the battery and mounted a ground stud on my H-donut amp mount and grounded both amps to that... plus there is now a future ground point just in case...
OKBigD is offline
post #4 of 4 (permalink) Old 04-13-2015, 10:13 AM
hometoast's Avatar
I'm pretty sure my ground to the fairing mount is the cause of my "pop" when I turn the radio on or off. Otherwise, it's great. But next time I've got it apart I'll run a new ground probably. (I need to get the faring off anyway to get the EZ pass mounted in the nose.)
2013 Candy Orange FLTRX
hometoast is offline
RG security gremlins? Putter Troubleshooting for Road Glides 8 10-12-2016 06:56 PM
Electrical charging gremlins mouser58 Troubleshooting for Road Glides 5 06-02-2016 10:28 AM
radio display fades out............... SWFLGLIDER *General Road Glide Discussions/Pictures 7 01-25-2010 06:49 PM
XM radio old school *General Road Glide Discussions/Pictures 1 01-18-2010 10:23 PM
Radio Station Scan ncbeast *General Road Glide Discussions/Pictures 2 12-09-2009 10:10 AM
