2015 J&M speaker in, need amp help - Road Glide Forums
post #1 of 5 (permalink) Old 04-14-2015, 09:26 PM Thread Starter
fugly1's Avatar
Ok, I've read I don't know how many threads on this and I'm still thoroughly confused.
I put in a set of J&M speakers on my 2015 RGS and couldn't be more disappointed, no bass, tinny sound and at 70mph might as well turn the music off cause I cant hear it.
I do have an ELF 2 channel amp and the J&M rca adapter harness from a previous install on my now gone 2012 RGC.
1. Anyone sell a plug n play harness to hook up the ELF 2ch.amp to the stock HD HU?
2. Easiest (simplest) location to install the ELF amp (similar to the ARC amp) under the fairing?
3. Only doing the amp and 2 fairing speakers, will I still need to flash the HU?
4. What's the ongoing rate for the reflash? Would prefer not to.
Not looking for a monster, competition type setup, just something that'll give decent fidelity and make music listenable at 70mph.
Many thanks for your advise, tips and suggestions, appreciated!
fugly1 is offline
post #2 of 5 (permalink) Old 04-18-2015, 05:27 PM
JMJOHN
JMJOHN's Avatar
THE most powerful 2-channel amplifier kit J&M has ever offered @ 330w total RMS power ((165w RMS per channel X 2)) ,,,,,
http://www.jmcorp.com/ProductDetail....D=JAMP-330HR15 ,,
JMJOHN ----
JMJOHN is offline
post #3 of 5 (permalink) Old 04-18-2015, 05:41 PM Thread Starter
fugly1's Avatar
John ...thanks for the reply but it doesn't address my main questions. I already have an amp ELF125 which is more than enough for what I need, I had this amp on my 2012 RGC with the J&M RCA harness and 7.25 Rokkers and it was awesome.
Wondering if I can use the RCA harness on the 2015 RGS, I already have the Rokker speakers installed.
Will the reflash be needed?
Any idea how much are dealers charging for the reflash?
Thanks again
fugly1 is offline
post #4 of 5 (permalink) Old 04-19-2015, 10:12 PM
JMJOHN
JMJOHN's Avatar
fugly ,,,,,
yes , the elf amp will work fine, WITH the correct adjustments and Harley radio FLASH like this http://www.jmcorp.com/PDF/HarleyRadi...04-02-2015.pdf ,,,,,,,
the J&M isolated rca input adapter will also work well with the Elf amp ,,,,,
JMJOHN ----
JMJOHN is offline
post #5 of 5 (permalink) Old 04-19-2015, 10:41 PM Thread Starter
fugly1's Avatar
Thanks for your time and the much needed info, much appreciated. I have a couple of dealers nearby, will check this week and see what kind of deal they offer me for the reflash, hopefully, the one I bought the scoot from and spent much of my $$ at will "cooperate".
Thanks again, John!! ...will post my results/update once everything is taken care of.
fugly1 is offline
Speaker lid speaker help Heavy Metal Audio 7 10-27-2017 03:07 AM
2015 RGS amp and speaker help needed peeweesherman Audio 5 04-04-2017 10:08 AM
Speaker and amp gurus? Need help! jp374 Audio 18 04-12-2016 04:45 AM
I need help with 6.5 speaker adapters... RIDERED67 Audio 22 09-20-2012 10:43 PM
speaker grill idea i need help with Swagzilla Aftermarket Accessories 18 02-26-2012 11:06 AM
