2012 Radio reception - Road Glide Forums
post #1 of 8 (permalink) Old 07-18-2012, 11:13 PM Thread Starter
cloud's Avatar
Ok, so my day old 2012 Road Glide Ultra is having radio issues.
Sitting still everything seems to work just fine.........start riding down the highway and the radio cuts in and out.......its not a power issue it seems more like maybe an antenna or coax issue. Anyone had issues? Where is the most likely place to start? I'd take it back to the dealer where I purchased the bike and bitch but thats 90 miles down the road.
Thanks in advance
Cut N Shoot Hog Chapter, Patriot Guard Rider
'05 FLTRI, Stage 1 setup and gear driven cams installed.
'12 FLTRU, Stage 1 setup, cams and tuner installed.
cloud is offline
post #2 of 8 (permalink) Old 07-19-2012, 06:04 AM
mine did the same thing one time and it was the AUTOMATIC SETTING to lower the sound when talking. If that gets set to high then any noise will lower the sound making you think its a loose connection when cutting out. Grab the owners manuel and make sure that setting is no more than 3 bars then try it.
HDRDH08 is offline
post #3 of 8 (permalink) Old 07-19-2012, 07:43 AM
It is a warranty issue take it back to the dealer if you can't solve the problem yourself. 90 miles is just a nice ride on a new bike so jump on the bike and ride .
post #4 of 8 (permalink) Old 07-19-2012, 08:45 AM Thread Starter
cloud's Avatar
I don't mind the 90 mile ride......its the fact that someone will have to come pick me up (and then at some point take me back) because the dealer will want to keep the bike for a week.....
cloud is offline
post #5 of 8 (permalink) Old 07-19-2012, 09:08 AM
If the dealer needs to keep the bike for a week to fix a simple problem then you need a new dealer. A real HD dealer should jump right on the problem especially on a brand new bike. IMO
post #6 of 8 (permalink) Old 07-19-2012, 09:24 AM
Mine did the same thing. Check the CB. Make sure its off.
ron66 is offline
post #7 of 8 (permalink) Old 07-20-2012, 09:08 PM Thread Starter
cloud's Avatar
Its a little early to be sure but..........I've turned the CB off and I think the issue has gone away...........
Thanks
cloud is offline
post #8 of 8 (permalink) Old 07-20-2012, 11:33 PM
radio issue
I'm betting the cb switch was the problem. Had the same issue a month ago when I "upgraded" to a 2012 from a 2004 model.
dpotis57 is offline
Radio Reception Question 15 RGS hatzo1 Audio 4 11-21-2015 05:22 PM
Poor Radio Reception cyndi46 Audio 0 10-15-2015 12:30 PM
HID light Bulbs killed Radio reception Straitline Audio 10 08-10-2014 08:25 PM
Poor Radio Reception ??? twistr Audio 6 11-08-2012 04:38 PM
A M Radio Reception Rant Fahred Audio 1 10-08-2012 07:55 PM
