Hidden antennae - Road Glide Forums
post #1 of 29 (permalink) Old 04-17-2015, 03:51 PM Thread Starter
SurlyBoy's Avatar
Hidden antennae
The bike is stripped down to the chassis for new paint and powder so I'm taking the opportunity to do a few other upgrades and clean a few thing up. I want to get rid of the antennas and was looking at the J&M hidden ones, both Am/FM and CB. I don't really use the CB but it's all wired for it so I don't want to get rid of it either. I'm putting in HID headlights and an amp and I've heard that HID's can interfere with the hidden antenna. Has anyone ever mounted one in the saddle bags? I Thought of puttin them in the tour pak but it's detachable so i don't always have it on the bike. I already have the cables run back to connectors mounted on the saddlebag supports as part of the quick detach kit.
Open to other ideas as well. I've seen where some people slide the antennae under the fender rail covers. Has anyone had luck with the shorty ones mounted down by the fender? They're not going back on the tour Pak. The mounts have already been removed and the painter is going to fill the holes before shooting the new color.
SurlyBoy is offline
post #2 of 29 (permalink) Old 04-17-2015, 07:39 PM
thedude's Avatar
I put my shorty under the side cover. It works fairly well with FM. I'm sure the range is cut way down but I really don't use FM much. The WB comes in sometimes and sometimes no. I figure if I really need the WB I'll stop and pull the cover off then stuff it back in once I hear the forcast. If I used it a lot this probably would not be a great set up but it works for me.
thedude is offline
post #3 of 29 (permalink) Old 04-18-2015, 03:11 PM
Rasconzo's Avatar
Im curious about this to. Going to upgrade the audio in the next couple weeks and would like to get rid of that big ole antenna.
>Project Darkside< 2015 FLTRXS
Stage V 120hp/120tq with V&H Propipe and RSD Turbine air cleaner, 14" Factory 47 Malo bars.
Rasconzo is offline
post #4 of 29 (permalink) Old 04-18-2015, 03:31 PM Thread Starter
SurlyBoy's Avatar
I think in gonna go ahead and order the J&M antennae and do some tests in the garage. I'll try the bags and he fairing before I remove any wiring
SurlyBoy is offline
post #5 of 29 (permalink) Old 04-19-2015, 10:14 PM
JMJOHN
JMJOHN's Avatar
surely boy ,,,,,,
let me know if I can be of any assistance along the way ,,,,,,
JMJOHN ----
JMJOHN is offline
post #6 of 29 (permalink) Old 04-19-2015, 10:16 PM
The Volusianator's Avatar
I have the original long antenna mounted in my fender strut, and it's basically useless.
The Volusianator is offline
post #7 of 29 (permalink) Old 04-19-2015, 11:22 PM Thread Starter
SurlyBoy's Avatar
Well John, I guess you'd be the very man to ask. Have you guys tried mounting the hidden antennae anywhere else? Or have you found interference to be an issue if there's an amp or HID's in the fairing?
Thanks
Dylan
SurlyBoy is offline
post #8 of 29 (permalink) Old 04-20-2015, 06:28 AM
RGUrider's Avatar
I use the J&M hidden fairing antennae. I don't use WB or CB, FM only. Seems to work OK, then again I don't use FM much either so it could suck for all I know. I guess reception is a matter of perception, in my case my setup works for what I want.
RGUrider is offline
post #9 of 29 (permalink) Old 04-20-2015, 06:41 AM
hometoast's Avatar
I'll report back after this weekend about mine. Same JM antenna... I also have to take faring off to install EZpass in the nose.
2013 Candy Orange FLTRX
hometoast is offline
post #10 of 29 (permalink) Old 04-21-2015, 05:44 AM
Wildmank99's Avatar
I have hidden antenna and hid's and amp inside the fairing and never had any problems
2007 road glide black pearl, 103 kit with aftermarket heads and cams, air ride, 2 to 1 bub pipe, and alittle bit of sounds
Wildmank99 is offline
Hidden Antenna? Wes10RG Aftermarket Accessories 11 10-25-2017 10:00 AM
Old Sirius Radio antennae will it work 2015 RGS bmoore951 Audio 1 11-01-2015 07:27 AM
DIY Hidden Receiver Hitch Sincecrazy Do-IT-Yourself 10 02-03-2014 07:56 PM
Looking for short CB antennae popovdave New Members Welcome Area 13 12-08-2013 05:27 PM
Tour Pak Antennae Wiring Soonerglide Audio 16 07-13-2013 06:13 AM
