AUX plug - Road Glide Forums
post #1 of 5 (permalink) Old 04-25-2015, 06:48 AM Thread Starter
AUX plug
It appears the aux plug in the HK Radio has broken. I use it to hear my GPS and XM Radio on the factory stereo. Is this repairable, or do I need to just start using my Walkman earbuds? I'm good with a soldering iron, so if I can get inside the radio, I can fix it. I use the CB and the Intercom, so going to a different radio won't work. 2011 RGU. Thanks.
If there's no ice on the roads, it's not too cold to ride.
Briano is offline
post #2 of 5 (permalink) Old 04-25-2015, 07:22 AM
pacfan1967's Avatar
http://www.okeswamp.com/
Ride safe, Gary
pacfan1967 is offline
post #3 of 5 (permalink) Old 04-25-2015, 07:23 AM
pacfan1967's Avatar
You can use that as a guide.
Ride safe, Gary
post #4 of 5 (permalink) Old 04-25-2015, 09:25 AM
Yes it is repairable. Pull the radio and then you can pull the face plate of the radio off then you can see the AUX plug and it's solder connections.
It isn't uncommon for one of the AUX plug pins that is soldered to the board to break off the board, and re-soldering the pin to the board is easy repair. If for some reason the AUX plug is broken in some other fashion the plug can be replaced.
post #5 of 5 (permalink) Old 04-26-2015, 02:17 AM Thread Starter
Thanks, Ironmark. I'm guessing that I have to pull the front fairing to get the radio out, so I guess I have a winter project....or at least a "couple of rainy weekends project".
Briano is offline
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 10:17 AM
Aux Plug Robare Audio 7 07-25-2012 11:19 AM
Aux Power Question buzzman_45011 Aftermarket Accessories 13 11-15-2011 05:40 PM
HK Aux not working abone Audio 4 07-24-2011 10:24 PM
Underseat Tap-in to the Aux circuit? mdwar2005 Tech Area 1 05-09-2011 08:07 PM
