HELP -- Why does my audio setup suck? - Road Glide Forums
post #1 of 16 (permalink) Old 05-01-2015, 03:51 PM Thread Starter
Installed J&M Rockers 6.65 in the fairing & Hogtunes 200W 4 channel amp in my 2015 RG.
It is louder but my speakers get distorted when I turn it up 1/2 way.
Spent a good amount of money & I am pretty disappointed at this point..
I plan to add speaker lids in the not too distant future, I hope that helps...
Any comments or advice would be very much appreciated.
Rycap is offline
post #2 of 16 (permalink) Old 05-01-2015, 03:55 PM
09Sharknose's Avatar
So are the j&m speakers the only set of speakers you have installed? Jmjohn is on the forum and may be able to help you out. It may just be a matter of flashing your radio or tuning your amp. Good luck.
At any rate, there are some serious audio dudes on this forum and eventually they'll nail it down for you.
09Sharknose is offline
post #3 of 16 (permalink) Old 05-01-2015, 04:10 PM Thread Starter
Yes, the J&M's are the only speakers that are in the bike currently.
Rycap is offline
post #4 of 16 (permalink) Old 05-01-2015, 04:37 PM
pipe3214's Avatar
My J&M sound great. I can't complain at all. They will help you out and your gonna be happy once its dialed in :-)
pipe3214 is offline
post #5 of 16 (permalink) Old 05-01-2015, 04:55 PM
Banshee451's Avatar
Flash the head unit - that should solve the distortion issue. The flash settings are in a sticky for this topic.
Banshee451 is offline
post #6 of 16 (permalink) Old 05-01-2015, 05:32 PM Thread Starter
There are two separate Flash posts.
I have the Hogtunes Amp.
After reading it appears I would follow post #1 with 594 views - correct?
Rycap is offline
post #7 of 16 (permalink) Old 05-01-2015, 06:23 PM
Banshee451's Avatar
Yes, that should make a big difference. I installed a PBR300 amp and Infiniti Kappa speakers. All was good but when cranking it up I had a lot of distortion. I printed out the post and the images, taking it with me to the dealer to show exactly what is needed. After the flash, I can crank it to a point it's hurting my ears without distortion.
post #8 of 16 (permalink) Old 05-01-2015, 06:34 PM
pipe3214's Avatar
I just took off my outer fairing and cut the pink and white wire and grounded it out and now my bluetooth and volume control both work. 702 motoring in Vegas set me up last summer and I'm more then happy with there products and service:-)
pipe3214 is offline
post #9 of 16 (permalink) Old 05-01-2015, 06:59 PM Thread Starter
Thank you. Will give it a shot & post an update once flashed.
Rycap is offline
post #10 of 16 (permalink) Old 05-13-2015, 02:59 PM Thread Starter
Got the radio flashed & it is much better - Thank you.
For the money I spent it still doesn't sound as good as I think it should..
Hopefully after the lid speakers go in, it will sound that much better.
Rycap is offline
How Bad Does This Suck? dvanlue General Off-Topic Discussions 24 07-12-2014 12:44 PM
I need help with my audio setup jeffreyjjc Audio 2 04-28-2013 10:57 PM
Why? Why? Why? CMS *General Road Glide Discussions/Pictures 16 04-11-2011 01:46 PM
Why does the 2011 RG deserve there own section ironmark *General Road Glide Discussions/Pictures 2 02-01-2011 11:37 PM
Why does HD have to use Chinese Parts on an American Motorcycle? BillyBob *General Road Glide Discussions/Pictures 41 01-27-2011 10:07 AM
