Audio Gurus - Please Enter!!! - Road Glide Forums
post #1 of 32 (permalink) Old 05-05-2015, 07:26 AM Thread Starter
OneSlickGlide's Avatar
Ok. So I just did a complete redo of my audio system. Pioneer HU (4v) preamp outs with PAC handlebar controls, Hertz HSK165XL's up front, HCX165's in speaker lowers, and HCX690 6x9's in a set of Hogtunes lids with a Hertz HDP4 amp in my bag.
Now I'm trying to setup my gains and such. What is the best way to do so?
I tried turning up the volume all the way up with gains set at 0. I get amp clipping at around 55( max I believe is 60-65). So do I back the volume down to around 45-50 and then start setting my gains? Adjust front gains until clipping happens and then back off?
Thanks
OneSlickGlide is offline
post #2 of 32 (permalink) Old 05-05-2015, 07:40 AM
http://knowledge.sonicelectronix.com...l-multi-meter/
2012 Road Glide Ultra
79HP 103 TQ, tuned by Ed at The Dyno Difference.
tsigwing is offline
post #3 of 32 (permalink) Old 05-05-2015, 08:18 AM Thread Starter
Thanks. That's a pretty good article. Thanks 👍👍👍👍
post #4 of 32 (permalink) Old 05-18-2015, 08:32 PM Thread Starter
Ok. So dilemma number 2.
My hertz amp took a crap. So while it is away getting fixed. I bought a nano PN4.1000D 4ch amp. Pretty much the same specs powerwise as my hertz amp.
The only physical difference is that it requires 2 RCA cables ran to it. One for front channels and one for rear channels. 3 sets of speakers hooked up in parallel. RCAS ran from my front and rear preamp out on my pioneer deck. Radio has high pass filter on and so does the setting on the amp.
Fronts play normally. Rear 6x9's seem to only play the music. No vocals. I'm assuming this is normal from the rear channel preamp.
Is there an RCA that splits from one junction into 2?
post #5 of 32 (permalink) Old 05-18-2015, 08:36 PM Thread Starter
Can I use something like this to split it? Run one out of the red port and one out of the white port on the front channel RCA out? That way I'm getting the same signal to both channels?
post #6 of 32 (permalink) Old 05-18-2015, 11:37 PM
09Sharknose's Avatar
Did you have 3 sets of speakers wired in parallel running to the Hertz amp?
09Sharknose is offline
post #7 of 32 (permalink) Old 05-19-2015, 04:37 AM Thread Starter
I have 3sets of speakers wired in parallel from my Nano amp. Channel 4 is open for future addition.
post #8 of 32 (permalink) Old 05-19-2015, 11:28 AM
Maybe I'm missing something, but if you have three sets of 4 ohm speakers wired in parallel on one channel, your amp is seeing 1ohm.
Audio gurus?
post #9 of 32 (permalink) Old 05-19-2015, 11:54 AM
mailman's Avatar
I was thinking the same thing - 1.33 ohm load at the amp. Sounds like a recipe for disaster?
Billy
mailman is offline
post #10 of 32 (permalink) Old 05-20-2015, 06:49 AM Thread Starter
Your right. I've been messing with it. I'm pretty new to this audio thing.
So could I run the front 2 sets of speakers in parallel (2 speakers/channel @ 2ohms/channel) and my 6x9's on their own channel (straight 1speaker/channel @ 4ohms/channel)?
attention Audio gurus need HELP Jims79FLH Audio 10 08-26-2015 09:08 PM
Please, Please, Please don't do this... cnidog Safety Area 13 09-01-2012 09:51 AM
Couple of questions for all you GURUS boneman171 *General Road Glide Discussions/Pictures 3 04-28-2012 10:17 PM
