AMP Install Power & Ground Wire Routing - Road Glide Forums
post #1 of 5 (permalink) Old 05-07-2015, 09:50 PM Thread Starter
wevsspot's Avatar
I'm taking delivery of the new RG this weekend. Have replacement speakers ordered and fixing to pull the trigger on a Soundstream PN2.350D Picasso amp.
I've done more car stereo systems than I can count so installation and wiring shouldn't be much of a problem once I get past the fear of taking apart the fairing on a brand new bike.
System will be; stock HU, Soundstream AMP and two fairing speakers.
I have two questions that I could use some "expert" help on though;
1. Power and ground wire routing for the amplifier. I'm going straight to the battery and would like to know if I have to pull the gas tank to get from point A to point B. My amp will be mounted in the fairing.
2. I'm still confused about the whether I need to flash the firmware on the HU. My bike is a standard so it has the 4.3 (not 6.5) HU. An easy yes or no would be helpful.
Thanks a bunch and thanks for the warm welcome. Long time Harley owner, but first time RG owner.
wevsspot is offline
post #2 of 5 (permalink) Old 05-07-2015, 09:59 PM
Speedie's Avatar
Yes, you will need to pull the tank to get to the wire wye. Not a big deal, just go slow and have a few towels handy to set the console and tank upon.
2015 Road Glide Special
Detachable Trunk : Detachable Passenger Back Rest
Rinehart Exhaust : De-Cat Headers : J&M 330W Rokker Amp and Speakers
Speedie is offline
post #3 of 5 (permalink) Old 05-07-2015, 10:02 PM
Speedie's Avatar
Check out this video for an idea of what needs to come apart ... https://www.youtube.com/watch?v=8a0p6IF2hS8
Speedie is offline
post #4 of 5 (permalink) Old 05-07-2015, 10:27 PM
Banshee451's Avatar
You might look at getting a copy of the Service Manual. I picked one up and have used it for the various adds to my 15 RGS -amp & speakers; LED front and back signals; hidden antenna; headset plug.
I had to flash my 6.5. Don't know about the 4.3, but I would suspect the answer is "yes" - you have to let the HU know the amp is there so it lets the amp do its work. I know the sound was MUCH better after I had the HU flashed - distortion gone at speed with volume.
Banshee451 is offline
post #5 of 5 (permalink) Old 05-08-2015, 09:27 AM Thread Starter
wevsspot's Avatar
Thanks gentlemen. Much appreciated.
wevsspot is offline
J&M Amp Ground Wire Help tsmartt Audio 6 05-29-2014 01:32 PM
Help with main ground wire. cruznmarine Audio 15 02-11-2014 01:12 AM
Amp wire and ground point Venomized Audio 6 01-09-2014 11:07 PM
Removing Ground Wire from turn Signal Housing.. gpdstaffcapt *General Road Glide Discussions/Pictures 0 03-27-2013 10:56 AM
Ground wire? Willy_B Audio 2 05-16-2012 11:08 PM
