info needed - Road Glide Forums
post #1 of 10 (permalink) Old 05-10-2015, 01:36 PM Thread Starter
mcrmb1's Avatar
Question info needed
Well im converting my RK to a Gulid i have everything but a head unit speakers and amp. Thinking of going with Rockers in fairing and a PBR-300X2 no ideal on head unit or handle bar controler. Trying to do this only once and also whats the best stero cover.
mcrmb1 is offline
post #2 of 10 (permalink) Old 05-11-2015, 07:29 AM Thread Starter
mcrmb1's Avatar
anyone help needed
mcrmb1 is offline
post #3 of 10 (permalink) Old 05-11-2015, 08:31 AM
Vtwin audio makes a very nice radio mount kit with a splash shield and their customer service is fantastic. As far as handlebar control I went with a controller from PAC and the scosche harness which makes it pretty much plug and play. Only one wire needs to be cut and grounded, very easy to use setup. The vtwin audio kit and PAC controller with scosche harness is a less expensive alternative to the hawgwired or Biketronics kits. As far as radios, amps and speakers there's many many options to choose from and I'm sure you'll get different opinions from everyone here. I used a pioneer head unit, 1200 watt amp and polk audio 6.5 in the fairing and polk audio 6x9 in the saddlebag lids along with the kits I mentioned earlier.
post #4 of 10 (permalink) Old 05-11-2015, 08:43 AM Thread Starter
mcrmb1's Avatar
ok do i need a marine if i use the splash guard
mcrmb1 is offline
post #5 of 10 (permalink) Old 05-11-2015, 09:36 AM
No, you don't need the Marine badge on HU or speakers.
I'm running the Alpine 149 bt, Sound Stream Nano 520D amp , and Infinity Kappa speakers.
I also used the install kit and splash cover from V Twin and the PAC interface . Sound and fitment are great. Ran in plenty of rain storms with out any problems.
post #6 of 10 (permalink) Old 05-11-2015, 10:54 AM
No you do not. Big Gary has a thread floating around which is very helpful when it comes to the PAC and scosche harness. Also because you won't need to use a marine grade radio it will give you many more options and price ranges for radios as long as it steering wheel compatible
post #7 of 10 (permalink) Old 05-11-2015, 12:55 PM Thread Starter
mcrmb1's Avatar
is this what i need PAC ControlPRO (SWI-CP5) and is the Vtwin splash guard the only one the make if so what holds it on
mcrmb1 is offline
post #8 of 10 (permalink) Old 05-11-2015, 06:58 PM
Go with Jensen HD1BT, bluetooth plug and play. Look at the J&M Rocker XX speakers and amp.
Harleyjohn66 is offline
post #9 of 10 (permalink) Old 05-11-2015, 09:00 PM
I'm not sure about that PAC but you'll need to buy the install kit with the splash guard. Once the radio is installed with the kit, the splash guard gets pressed into place from the outside. You can remove it when not needed if you choose but I keep it on all the time. I believe the pac controller I used was PAC-SWI with the scosche harness. I think the one you mentioned might the new version but I'm not sure
post #10 of 10 (permalink) Old 05-12-2015, 08:33 AM Thread Starter
mcrmb1's Avatar
well the PAC ControlPRO (SWI-CP5) from what i have a read gives you 12 opt. for controles
mcrmb1 is offline
North East Georgia Info needed bcultra Road Trip Discussions/Stories/Pictures 6 02-26-2013 10:09 AM
Info needed on Bassani true duals marvo75 Intake and Exhaust 2 02-03-2013 07:42 PM
Info needed for Fort Myers area Harley Rentals Silverbullet *General Road Glide Discussions/Pictures 10 01-10-2013 10:28 PM
Info Needed Jetman ECM/Fuel Management systems 20 03-01-2012 04:39 PM
Boom Cans info needed BigLew Intake and Exhaust 2 10-13-2011 05:42 PM
