High pitched squeal from speakers. - Road Glide Forums
post #1 of 3 (permalink) Old 05-19-2015, 05:28 PM Thread Starter
09Sharknose's Avatar
Cranked up the bike and had a high pitched squeal coming from rear channel mostly, but have a slight one on forward channel before the music starts.
Very high pitched, sounds like fingernails on a chalkboard.
Thoughts?
09Sharknose is offline
post #2 of 3 (permalink) Old 05-19-2015, 05:46 PM
Thoughts?
At first I thought , its his taste in music . Might want to double check your grounds.
post #3 of 3 (permalink) Old 05-23-2015, 01:17 PM Thread Starter
I had pinched a wire running under the seat to the point that the coating had rubbed off and it was shorting out when it touched the metal frame. Thanks Big Gary!
Brake squeal on a 2016 starsky Equipment-RG 1 07-03-2017 10:11 AM
Brake Squeal sifugumba Wheels and Tires 4 07-12-2015 09:44 AM
Squeal in front end newtome Suspensions 4 10-18-2014 09:03 PM
New Lyndall Z w/ Hog Pro rotor squeal Murlsquirl Wheels and Tires 5 10-30-2012 01:56 PM
squeak/squeal from rear palmpalm *General Road Glide Discussions/Pictures 9 09-24-2012 10:32 AM
