Question about 4 ch 500W J&M amp w/ 2013 RG Harman Kardon - Road Glide Forums
post #1 of 7 (permalink) Old 05-22-2015, 06:20 PM Thread Starter
McGruder's Avatar
I got the 500W 4 channel J&M XTP amp, but I how I'm supposed to provide the input signal to the rear RCA inputs on the amp.
1 - Should I splice the stock front speaker output into both front and rear RCA inputs on the amp?
2 - Can the stock head unit on a 2014 RG be flashed to have front to back fader controls?
3 - Also, I'm wondering if it would be better to use a line level convertor on the signal, and use the "preamp" setting on the amp instead of "speaker" input.
Thanks in advance.
2013 RGC - SE Stage 4, V&H Dresser Duals, Rinehart 4", Progressive Monotubes/Ohlins 357, Khromewerks Extend Heritage bars, Daymakers,
J&M 500W XTP amp, 4 Rokker XX speakers, BADDAD lids, Road Tech 665
McGruder is offline
post #2 of 7 (permalink) Old 05-22-2015, 07:17 PM
Thanks in advance.
You might want to ask John in the J&M section. I know on the Rockford fosgate Punch amps you cut the rca plug off and wired off the head units speaker wires (high level connection) and left the remote wire unused. I'd first check with John on his amp.
if you ment 2013 RG RX ?? !Yes, a simple flash turns on the fader.
post #3 of 7 (permalink) Old 05-22-2015, 07:25 PM Thread Starter
McGruder's Avatar
After re-reading the J&M amp instructions, I now understand that that provided wires terminated with pins that I have to plug into the NUOH (Non-Ultra Override Harness) to obtain the rear speaker signals.
Also, apparently Harley can flash the HK head to activate a Fader control. I wonder if that adds Balance control also.
I'm still also wondering if its worthwhile to use a line level convertor with J&M's "preamp" amp input setting, or speaker level feeding the amp's "speaker" setting is just as good, or does the same thing.
Ken
McGruder is offline
post #4 of 7 (permalink) Old 05-22-2015, 07:30 PM
I sent the HK to Iron Cross Audio for the F&R Preamp Outs, ICA includes the Fade flash.
HeatWave is offline
post #5 of 7 (permalink) Old 05-24-2015, 11:03 AM
JMJOHN
JMJOHN's Avatar
McGruder ,,,,,
the J&M ROKKER XTP amp kit should have been 100% plug-n-play for your specific model Harley Bagger,,,,,,
what is the year & model of your Harley and what is the exact model number of the J&M ROKKER 500w amplifier kit that you purchased ? ,,,,
I will help you get this done ,,,,,
JMJOHN ----
JMJOHN is offline
post #6 of 7 (permalink) Old 05-24-2015, 12:48 PM
Admin
BillyBob's Avatar
John can help you with this😎😎😎😁
BillyBob is offline
post #7 of 7 (permalink) Old 05-26-2015, 05:08 AM Thread Starter
McGruder's Avatar
Originally Posted by JMJOHN View Post
McGruder ,,,,,
John - Thanks for checking in on my install. It's all done and working and sounding great on my 2013 RGC/FLTRX. I just wanted to make sure I'm getting the optimal sound quality.
I noticed 2 settings on the input. As you noted, it was pre-configured to receive the (speaker level) output of the HK head unit, interfaced to the J&M amp through the RCA inputs. There was an alternative setting on the unit for pre-amp input, and I wanted to make sure that using a 3rd party line level convertor fed into the unit with preamp setting was not a preferred setup for sound quality.
This was a significant boost in the system's loudness and clarity over the previous lower powered systems through the 2 front speakers. Thanks...
Ken
McGruder is offline
Harman Kardon radio from 2013 SG bikerglasses Parts for Sale 3 01-11-2017 07:29 AM
2013 Harman Kardon Head Unit, $175 shipped Trip20 Parts for Sale 0 09-09-2016 05:22 PM
2013 Harman Kardon "Powerup Failure" Kudu40 Audio 1 07-01-2014 02:24 PM
Harman Kardon Stock Radio off 2013 Road Glide Custom ScreamingSkulls Sold 2 09-13-2013 01:38 PM
Harman Kardon HD Radio Repair theandyman Equipment-RG 2 07-02-2011 01:59 PM
