Problems programming handlebar controls - Road Glide Forums
post #1 of 16 (permalink) Old 05-25-2015, 09:33 PM Thread Starter
Drag 2013's Avatar
I got rid of the stock HK head unit, and the Hog Tunes REV kit in my bike. I installed a Pioneer DEH-X8700BH head unit with the V Twin Audio face plate and splash guard. I replaced the amp with a Rockford Fosgate T400X2AD, and the speakers with Infinity Kappa 62.11i's. I was trying to program the Axxess box to make my switches work. For some reason, when the bike has the ignition on but not running, it works fine. When the bike is running, the volume up changes the CD to the previous track, volume down turns the volume up. The right switch makes the radio mute, and none of the other switch functions do anything. Very confusing, and getting very annoying. Anyone else have this problem?
Drag 2013 is offline
post #2 of 16 (permalink) Old 05-28-2015, 10:40 PM Thread Starter
Drag 2013's Avatar
Bump... Nobody else had this problem?
post #3 of 16 (permalink) Old 05-29-2015, 08:41 AM
I know on some HB modules you need to cut a oem wire in the fairing & ground it. Not familiar with yours.
post #4 of 16 (permalink) Old 05-30-2015, 01:20 AM Thread Starter
Drag 2013's Avatar
Yeah, I did the pink/white wire if that's what you mean.
post #5 of 16 (permalink) Old 05-30-2015, 07:12 AM
Are you using a PAC controller for the controls? If you are make sure you ground the correct side of the cut pink/white wire. I'm using the PAC controller but I mistakenly grounded the wrong end of the pink wire and could not for the life of me program it. After about 30 mins I realized what I did and grounded the proper end. After that the programming took about 5mins and works great
post #6 of 16 (permalink) Old 05-30-2015, 09:46 AM
Yes, thats right . Did you cut the right one , and ground the correct side ?
post #7 of 16 (permalink) Old 05-31-2015, 07:36 AM Thread Starter
Drag 2013's Avatar
My buddy that does custom stereo installation was actually the one that hooked up the Axxess box. Im pretty sure he had it hooked up right. At first he accidently hooked up the wrong side of the cut pink wire, but the controller didnt work at all. Then he switched it, and it worked fine until I disconnected the battery to rehook up my battery tender.
post #8 of 16 (permalink) Old 05-31-2015, 08:46 AM
Check your grounds are clean & tight.
post #9 of 16 (permalink) Old 05-31-2015, 07:31 PM Thread Starter
Drag 2013's Avatar
I soldered my Axxess box into the radio ground that I soldered into the Metra wiring harness adapter that plugs into the stock radio harness. Was i supposed to ground the Axxess box directly to the frame?
post #10 of 16 (permalink) Old 06-01-2015, 08:45 AM
I would.
Alpine 149bt and biketronics handlebar controls GrafixxMan Audio 3 05-19-2014 03:16 PM
iPod control using handlebar controls Joel Daniels Audio 0 05-17-2012 10:27 AM
Chrome Handlebar Controls forestgump Controls & Handlebars 9 04-30-2012 07:10 AM
right handlebar controls and radio not working (02 e/glide classic convert r/glide) criio1 Troubleshooting for Road Glides 1 07-16-2011 05:34 PM
Programming rear channels of head unit Sim Audio 1 03-03-2011 11:38 PM
