New Head Unit - Road Glide Forums
post #1 of 2 (permalink) Old 06-01-2015, 09:48 PM Thread Starter
glidethru's Avatar
New Head Unit
ok..If I replace my stock HK head unit with a new Sony head unit I want, I have a question. The stock HK unit is 2 ohm and the Sony unit is 4 ohm..right now I have a PBR 300x 2 powering a pair of J&M Rokkers. Will the swap out work just like stock since it is 4ohm.. Will I be able to use this head unit without swapping out for new amps and 4 ohm speakers
MAGNA FLOW "Top Guns
Wild Ones 12" Chubbys
glidethru is offline
post #2 of 2 (permalink) Old 06-01-2015, 10:18 PM
Desertwndrr's Avatar
You can swap the head unit with no issues. Since you are using the amp you will not be using the amp section of the head unit. Doesn't matter at all what ohm the head unit is putting out whether it is the old HD unit or the new Sony unit. Quit using the line inputs of the amp and use the RCA inputs.
Desertwndrr is offline
Should I get new head unit? Perlinal Audio 7 03-16-2014 03:03 PM
Problem Installing New Head Unit RedDogNC Audio 9 02-13-2014 08:32 PM
New HEad unit in old bike scayne62 Audio 10 01-06-2014 09:14 AM
Suggestions wanted: new head unit HellInABucket Audio 21 06-24-2013 08:52 AM
Improvement with new head unit? firstborn Audio 19 05-18-2012 10:21 AM
