Rear Speaker Help! - Road Glide Forums
post #1 of 7 (permalink) Old 06-01-2015, 10:24 PM Thread Starter
Papagonza's Avatar
Rear Speaker Help!
I may not be searching with the right question so, here it is. The volume control on the rear speakers (side of tour pack) doesn't seem to be working. I've tried all three positions on the speaker switch but get no response from the rear control. Is there a trick? Wifey doesn't like the vibration on her legs and says just take them out.😕 I prefer to have them if I'm riding alone to work. Some help please! Thanks
Papagonza is offline
post #2 of 7 (permalink) Old 06-01-2015, 10:29 PM
glidethru's Avatar
Check the Fade control on your head unit, see if that works, and take all the power to the front.
MAGNA FLOW "Top Guns
Wild Ones 12" Chubbys
glidethru is offline
post #3 of 7 (permalink) Old 06-01-2015, 10:31 PM
ironmule's Avatar
Did you check rocker switch on -off ?
ironmule is offline
post #4 of 7 (permalink) Old 06-01-2015, 10:59 PM Thread Starter
Papagonza's Avatar
glidethru..I'll check that in the morning but I believe its working.
ironmule..yes, checked rocker switch. Had no effect on the rear volume control.
post #5 of 7 (permalink) Old 06-02-2015, 01:31 AM
09Sharknose's Avatar
As I understand it, the switch you're referring to controls the volume in the passenger headset, not the speakers. The speaker volume is controlled by the fade function from the main system. I may be wrong, but check your manual.
09Sharknose is offline
post #6 of 7 (permalink) Old 06-02-2015, 05:20 AM
neverdone's Avatar
Correct 09. Have to have your headset plugged in.
neverdone is offline
post #7 of 7 (permalink) Old 06-02-2015, 07:03 AM Thread Starter
Papagonza's Avatar
09, bought used. No manual but you where correct. Thanks for the quick response guys. Now to upgrade the speakers! 😏
Lower Fairing Speaker pods: How did you guys run the speaker wire? Slider57 Audio 3 02-10-2018 03:12 PM
Speaker lid speaker help Heavy Metal Audio 7 10-27-2017 03:07 AM
6"x9" speaker kit that fits HD speaker lids JuicedHD Audio 1 01-18-2013 06:19 PM
need a little help finding my rear speaker wires mroach Audio 3 03-18-2012 08:30 AM
Hog Tunes Rear Speaker Pods Shrug *General Road Glide Discussions/Pictures 3 04-06-2010 11:03 PM
