Amp install - Road Glide Forums
post #1 of 9 (permalink) Old 11-03-2015, 04:04 PM Thread Starter
goose2's Avatar
Amp install
Can someone give me an idea as to where to install my amp on my 16 road glide. I am not so sure I see enough room in the fairing area.
goose2 is offline
post #2 of 9 (permalink) Old 11-03-2015, 04:16 PM
Smarty's Avatar
It goes below the radio. Remove the radio with the 4 bolts and it comes right out. Then you will see the area well.
Smarty is offline
post #3 of 9 (permalink) Old 11-03-2015, 05:12 PM
Q-Hog's Avatar
Subscribed
Q-Hog is offline
post #4 of 9 (permalink) Old 11-03-2015, 07:58 PM
You can remove the headlight assembly and the amp will slide right in underneath the radio. The four bolts that hold the amp's brackets are a little hard to reach but not all that bad. This is if you are using the Boom audio amp.
jims2015 is offline
post #5 of 9 (permalink) Old 11-03-2015, 08:24 PM
Witch amp. are you trying too install ?
dozer23 is offline
post #6 of 9 (permalink) Old 11-04-2015, 11:14 AM
I just installed the PBR300x4 in my 2016. It fits under the radio. I plan to do a write up with pictures on it as I change the speakers out as well to Polk Dxi6501.
2016 Road Glide (Amber Whiskey)
Hennessy is offline
post #7 of 9 (permalink) Old 11-04-2015, 12:53 PM Thread Starter
goose2's Avatar
That is the same amp I have. I would love to see how you have it mounted.
goose2 is offline
post #8 of 9 (permalink) Old 11-04-2015, 01:46 PM
Smarty's Avatar
To get an idea, go to the J&M site and watch their video. Really easy.
Smarty is offline
post #9 of 9 (permalink) Old 11-04-2015, 03:16 PM
Goose2.. Take a look at https://www.roadglide.org/53-audio/24...m-install.html
Hennessy is offline
AMP Install Power & Ground Wire Routing wevsspot Audio 4 05-08-2015 09:27 AM
Buky Malo install problems! Love the bars! Just a FYI on the install! bigshaqa *General Road Glide Discussions/Pictures 14 04-08-2014 01:37 PM
Daymaker Light Install - Install Problem - And Resolution Martin Lighting 22 06-06-2013 07:57 PM
Amp Install & HK Radio Warranty scooterroid Audio 5 08-30-2012 02:42 PM
amp & speaker install Trex69 Audio 2 07-17-2012 07:20 AM
