Amp, Speaker and Garmin 590LM Install - Road Glide Forums
post #1 of 8 (permalink) Old 11-04-2015, 03:05 PM Thread Starter
Figured I could contribute as someone maybe wanting to do the same thing. As I was not a fan of the sound, I decided to upgrade and put my 590LM on as it was great on my last 6000 mile trip from Jax to Nova Scotia and so forth.
Amp: PBR300x4
Speakers: Polk DXi 6501 (Marine Ceritified)
GPS: Garmin 590LM
The whole process is fairing simple:
1. Remove the outer fairing (used video on youtube for 2015 RG)
2. Remove the headlamp assembly ( 4 bolts: 2 top and 2 bottom)
3. Remove the radio 4 bolts (same tool used in #2 works here)
4. Remove the subassembly that holds the speaker (6 screws same as tool for removing speaker)
Deciding on where to place the amp and component was the only thing i needed to figure out. I thought about making a bracket however I found an easier way. Just used industrial velcro and zip ties. The component crossover was velcro'd and zip tied left and right of the radio as I do not have the cb and xm components. No wires were cut during the whole process. For the 590LM I used the audio out to the aux in which is harley part number 69200907 and ran in down below the fairing heat shrink and zip tied.
The only thing left to do is:
Have the radio flashed for AUX ON rename to "Garmin 590LM"
Have the eq flashed to a flat curve per RockfordFosgate
Hopefully this helps someone else out.
2016 Road Glide (Amber Whiskey)
Hennessy is offline
post #2 of 8 (permalink) Old 11-04-2015, 03:07 PM Thread Starter
Hennessy is offline
post #3 of 8 (permalink) Old 11-04-2015, 03:09 PM Thread Starter
attachments 2
Hennessy is offline
post #4 of 8 (permalink) Old 11-04-2015, 03:10 PM Thread Starter
attachment 3
Hennessy is offline
post #5 of 8 (permalink) Old 11-04-2015, 03:11 PM Thread Starter
attachment 4
Hennessy is offline
post #6 of 8 (permalink) Old 11-04-2015, 03:11 PM Thread Starter
attachment 5
Hennessy is offline
post #7 of 8 (permalink) Old 11-07-2015, 02:23 PM
Texas Rapier's Avatar
an I get a little more explanation on the wiring connections required.
2018 Road Glide Ultra (Electric Blue)
Retired Coast Guard Chief Engineer.
Texas Rapier is offline
post #8 of 8 (permalink) Old 11-08-2015, 01:45 PM Thread Starter
Texas..sure..the speaker wire on the motorcycle uses the terminals attached here. i soldered the male terminal to each input wire of the pbr300x4and then connected the two together. On the output side of the amp i ran the output wire to the component crossover input. Then the speakers wires are ran to the respective crossover output (attachement 5 1st pic). On the pbr300x4 it has a connector that has a 4 wire into rca. i cut those so that i could use the hi input. The 4.3 radio does not have rca output. Let me know if this helps. Will try to find a picture that shows it. I'm out of town till late Friday.
Hennessy is offline
Zumo 590LM Sharkbreath GPS 15 07-04-2016 03:47 PM
Garmin 590LM dsigrist GPS 2 03-18-2015 05:54 PM
Garmin Zumo 550 Install brightonrider GPS 14 11-27-2013 01:20 PM
amp & speaker install Trex69 Audio 2 07-17-2012 07:20 AM
J&M headset amp w/ Garmin GPS mount coryo Classifieds Archive (3 months old+) 2 05-13-2012 05:11 PM
