Herz HSK165XL & HCK165 - Road Glide Forums
  • 1 Post By tj316
post #1 of 9 (permalink) Old 11-04-2015, 05:01 PM Thread Starter
tj316's Avatar
I just ordered these speakers , the HSK165XL for my fairing and HCX165 for my lowers based off dbells recommendation. I removed my Sony head unit and put the stock unit back . Will I be ok with this set up and do I run the speakers parallel with my Hawg Wired RS400 amp ??? THANKS
tj316 is online now
post #2 of 9 (permalink) Old 11-04-2015, 05:52 PM
09Sharknose's Avatar
As far as running them in parallel, the answer is yes because the RS400 only has two output channels.
Any reason you're going back to the stock head unit?
09Sharknose is offline
post #3 of 9 (permalink) Old 11-04-2015, 06:02 PM Thread Starter
tj316's Avatar
I had a Sony head unit and I am not an audio guy , with all the features it had I just never felt I could dial it in properly , simple is better for us older guys
tj316 is online now
post #4 of 9 (permalink) Old 11-04-2015, 06:06 PM
Well those speakers rock! Good luck!
post #5 of 9 (permalink) Old 11-04-2015, 06:30 PM
Lol, Tim, who are you referring as to being old? That's basically the set up I have in front, you're going to like it. I think I would keep the Sony, but that's personal preference. Also, you do have Hawgwired grills, right?
post #6 of 9 (permalink) Old 11-04-2015, 06:43 PM Thread Starter
tj316's Avatar
Yes I have the grills , how did you cut the hole for the tweeters ? Also I may go to a Alpine head unit , I only use radio and CD(this shows I'm old) any thoughts on a simple to use head unit ?
texas glide likes this.
tj316 is online now
post #7 of 9 (permalink) Old 11-04-2015, 07:11 PM
If you only use the radio and CD player, keep the stock head unit. It is easy to use and with that amp and speakers you should get plenty of quality sound. IMHO.
Hawkman
2017 Lagauna Orange FLTRX, 2013 Candy Orange Road Glide Custom (traded), 2010 Ultra Classic (traded), 2004 Classic (sold to little brother), 1999, Classic (traded), 1999 Road King (best handling so far), 1994 Softail Custom (traded), 1974 Superglide (I miss her still).
Hawkman is offline
post #8 of 9 (permalink) Old 11-04-2015, 07:59 PM
I love my 149bt, has radio, cd, and much more, since the screen is LCD you can see it a little better in the day than most aftermarket led screens. I'll look to see what size hole saw I used for the grill.
post #9 of 9 (permalink) Old 11-06-2015, 02:45 PM Thread Starter
tj316's Avatar
David , I just looked , all I have are the original grills which are kind of thin plastic with cloth over them and hawg wired tweeter grills. Do I need to order a set of Hawg Wired metal grills to mount the tweeters ??? I looked on Hertz web the hole size is 1 13/16" . THANKS , also what did you wire your tweeter to on the crossover , +1, 0 or-1
tj316 is online now
DETAILS - PA & MD (& VA & ??) Meet & Greet 2017 08Zinc Organize Rides Here 28 05-10-2017 01:50 PM
Brand new J & M ROKKER XT speakers in the box Djtman Parts for Sale 9 02-23-2016 02:27 PM
J&M Rokker Speaker & AMP Review BillyBob J&M 12 01-20-2013 01:51 PM
Ordered J&M upper,lowers & amp jimmyray11349 Audio 9 12-17-2011 08:36 PM
Fine tuning J&M 250w amp & 7.25 Rokkers? Ny Chief Audio 8 07-06-2011 02:05 PM
