Couple of AMP Install Questions - Road Glide Forums
 2Likes
post #1 of 20 (permalink) Old 11-10-2015, 09:51 AM Thread Starter
wevsspot's Avatar
My shiny new Cerwin-Vega B2 amp arrived last night and I had time to put it on the bench and test to make sure that everything worked before I start tearing into the bike.
I have a couple questions that I'm hoping someone here can answer.
Bike is 2015 Road Glide with stock 4.3 HK radio
1. What diameter ring terminal is required for power line connection to the battery terminal? Is is 1/4", 3/8", 1/2" or other?
2. Anyone have speaker wire color code for front left and front right?
The only info I've found is from Hawg Wired and they say;
Front Left + / White-Orange
Front Left - / Light Green - White
Front Right + / Gray-Red
Front Right - / Light Green - Black
Are those correct? Any help on the two questions would be greatly appreciated.
Thanks.
wevsspot is offline
post #2 of 20 (permalink) Old 11-10-2015, 10:01 AM
wires are gonna be pink in color...the pink with the black stripe is positive.. cant miss them they are going into the speaker boxes on either side inside the fairing
mrsayes is offline
post #3 of 20 (permalink) Old 11-10-2015, 12:12 PM Thread Starter
wevsspot's Avatar
I found an online photo of the service manual for 2014 touring showing the following;
Left Front Negative Pink/Gray
Left Front Positive Pink/Orange
Right Front Negative Pink/????
Right Front Positive - Pink
That look right?
wevsspot is offline
post #4 of 20 (permalink) Old 11-10-2015, 02:40 PM Thread Starter
wevsspot's Avatar
Ok, the battery post bolt is 10MM so now I know what size ring terminal I need. Just an FYI for anyone else needing the same info in the future.
wevsspot is offline
post #5 of 20 (permalink) Old 11-10-2015, 03:42 PM
Smarty's Avatar
That look right?
Yes, and the other side is pink/black I think. I remember they were just slightly different
Smarty is offline
post #6 of 20 (permalink) Old 11-11-2015, 08:17 AM Thread Starter
wevsspot's Avatar
Thanks for the confirmation Shorty. Much appreciated!
Also, for anyone needing this info in the future.......
The battery post bolt is 10MM and requires a 1/4" ring terminal to connect accessories or AMP.
wevsspot is offline
post #7 of 20 (permalink) Old 11-16-2015, 11:49 AM Thread Starter
wevsspot's Avatar
Over the weekend I finished the installation of my new AMP (Cerwin-Vega B2) to compliment the JBL GTO638 speakers that I installed the first week I bought the bike.
All I can say is Wow. AMP install was ALOT of hard work, especially fitment in the shark nose, but it was well worth it.
AMP gain was set using a digital multimeter and the crossover frequency set by ear. The GTO638 speakers don't really play well with frequencies below 100hz at high power input and high volume. My input voltage to the speakers is approximately 31.62v and crossover is set at 120Hz (best guess).
This allows for almost uncomfortable volume levels when the bike is running.
The GTO638 speakers are rated 50Hz-21,000Hz at 60W RMS and that is probably a pretty fair and accurate rating. Just be advised that if you want high volume when jamming down the highway at 80mph you will probably want to set your crossover frequency somewhere above 80Hz minimum.
wevsspot is offline
post #8 of 20 (permalink) Old 11-16-2015, 12:19 PM
Just curious why you felt the amp install was "a lot of hard work"? Im cracking mine open shortly, but opted for the biketronics amp so that I could use their mount to make the job easier (at least I hope). I actually wanted the B52 amp.
MisterD is offline
post #9 of 20 (permalink) Old 11-16-2015, 12:28 PM
09Sharknose's Avatar
Why would adjusting it to crossover above 80Hz matter? I assume that's the low pass freq which would mean everything above 80Hz would come through anyway. Now if that's the high pass freq, that would be interesting for a set of 6.5 speakers.
09Sharknose is offline
post #10 of 20 (permalink) Old 11-16-2015, 12:45 PM
! rock103 !'s Avatar
Thanks for the info! I'm no stereo savvy tech guy, so this will help me alot. I think...!
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
JUsta a couple of pics of the bus from the last couple of days! ChromeYellow67 *General Road Glide Discussions/Pictures 31 11-24-2012 10:41 AM
couple of questions masonc *General Road Glide Discussions/Pictures 22 04-29-2011 12:21 AM
A couple of questions Hollywood Voo ECM/Fuel Management systems 2 04-15-2011 04:56 AM
Couple of questions... Osuno77 Troubleshooting for Road Glides 5 01-24-2011 08:58 PM
A couple questions??? RWB427 *General Road Glide Discussions/Pictures 3 12-07-2010 07:44 PM
