HELP! remove seal pin from P&A connector - Road Glide Forums
  • 1 Post By Gary R
post #1 of 3 (permalink) Old 11-22-2015, 12:23 PM Thread Starter
Gary R's Avatar
Anyone know how to Remove seal pin from cavity 12 of P&A connector, as required to add the rider headset harness?
It's step 2 of these instructions.
http://www.harley-davidson.com/app-c...ts/-J05870.PDF
My seal pin is recessed to far into the back of the connector and can barely grab it. It won't pull out from the back.
So I removed the rubber strain relief from the back just enough to grab the seal plug.
It won't pull out. It does seem to move forward some but not enough to think that's the correct way to push.
It appears I have to disassemble the entire connector just to remove this dang seal pin.
Or I need an extraction tool like the ones used on military type circular connectors.
http://www.aiconics.com/contact-inse...ion-tools.html
Edit: evidently some claim I just need a paperclip or maybe a small drill bit to unlock the pin from front of connector.
Well I tried a #60 drill bit which fit what may be an pin unlock hole, but it didn't unlock the seal pin.
So I'm still needing help I guess.
Any help would be appreciated.
Gary R is offline
post #2 of 3 (permalink) Old 11-22-2015, 02:07 PM Thread Starter
Gary R's Avatar
As I originally expected, I had to completely disassemble the rear of the connector to unlock the seal pin which didn't need to be there in the first place. In fact it wouldn't have been any more trouble to just install a short black wire in that position instead of the seal pin. Anyway I'm back on the road now.
9over likes this.
Gary R is offline
post #3 of 3 (permalink) Old 11-23-2015, 05:51 PM
9over's Avatar
Feels good to finally get it out!!!
9over is offline
front turn signal ground pin connector help HDBoy50 Lighting 12 01-19-2019 03:45 PM
Anyone re-pin a Molex Connector? ironmark Troubleshooting for Road Glides 9 03-25-2015 12:27 PM
Apple 30-pin dock connector to Apple Lightning wingman05 Audio 8 05-20-2014 01:47 PM
If the weather seal does not seal, what is the point?? Govdog76 Aftermarket Accessories 3 02-21-2012 08:48 AM
Tail light connector pin out. Spike Troubleshooting for Road Glides 3 04-01-2011 07:23 PM
