Amp wiring question - Road Glide Forums
post #1 of 3 (permalink) Old 11-24-2015, 12:18 AM Thread Starter
sharknose10's Avatar
Amp wiring question
I just installed 4 Hertz 165.1 in my fairing and a pair of ST 25 horns in the gauge holes. I also have a set of lid speakers. I want to run the two sets of Hertz off my Arc Audio 125.4 and the horns and lid speakers of my Diamond Audio Micro 4. My Alpine 149 BT has three sets of rca's, can I run a 4 channel amp off 1 set of rca's? I'm not sure how to wire the 2 amps. I've read where guys say to run the 4 Hertz off one amp and run the horns separately so they can be tuned easier. Thanks in advance.
2010 RGC, 21/17 Wanaryd, Top Shop bags, fender,side covers, Dragula 2, Ness Legs, PM mirrors, SE heavy breather, Alpine 149BT, 4 Hertz 165.1, Hertz ST 25, CVO lids with Hertz 6x9ís, powered by Micro 4 amps, Battistinis boards, Vindikta 12" bars.
sharknose10 is offline
post #2 of 3 (permalink) Old 11-24-2015, 08:30 AM
09Sharknose's Avatar
The 149 has three sets of RCA preouts: front, rear, and subwoofer. For your setup you will only run front and rear. I don't know the specs of the amps you have, but I assume they are 4 ohm.
You will run one set of rca from the fronts to the arc amp and then run speaker wire from the amp to the four speakers in the front.
Run another set of RCA from the rear preouts to the other amp. Wire the speakers the same as the front.
09Sharknose is offline
post #3 of 3 (permalink) Old 11-26-2015, 09:41 AM
Not familiar with the amps that you have however you probably need y adapters.
hades02 is offline
rockford pbr300x2 question on wiring suicidecj5 Audio 12 07-02-2015 11:02 AM
J&M 250 watt amp, 7.25 speakers, adapters, bracket, and wiring SEUGOT1 Sold 10 02-25-2013 07:10 AM
Internal wiring question matty3000 Do-IT-Yourself 8 11-07-2012 08:25 PM
Wiring Question On CVO Fascia PC PaiN *General Road Glide Discussions/Pictures 21 07-05-2011 12:10 PM
Tour-light wiring question? Roadglider09 *General Road Glide Discussions/Pictures 3 03-13-2011 08:04 PM
