2014+ Tour Pak Speaker Pods - Road Glide Forums
post #1 of 7 (permalink) Old 11-25-2015, 02:22 PM Thread Starter
Q-Hog's Avatar
Looking for anyone that have installed 2014+ Tour Pak Speaker Pods
Q-Hog is offline
post #2 of 7 (permalink) Old 11-25-2015, 03:12 PM
Mach1's Avatar
I installed some a couple months ago. Took my time and finished in an afternoon. Turned out great.
Mach1 is offline
post #3 of 7 (permalink) Old 11-25-2015, 03:36 PM Thread Starter
Q-Hog's Avatar
Did you take any pics. I've been holding off for months now and I'm finally deciding on installing them. Any pointers or advise? Thx
Q-Hog is offline
post #4 of 7 (permalink) Old 11-25-2015, 04:08 PM
Mach1's Avatar
Q-Hog, I didn't take any pics during install. Looking back I probably should have. The trickiest part is obviously cutting the holes in the Pak. I deviated from the instructions in this regard. The instructions say to go straight ahead and drill a 1 1/4" hole (can't remember the actual size). When you tape off the section you're going to cut and trace the hole, you'll see that this is a pretty ballsy move. It's a really large hole right on the corner of the pak. I decided I would drill a 3/4" hole first. I then went in with a Dremel and slowly increased the diameter of the hole until the plastic bracket that mounts on the inside of the Pak fit. It worked out great and was much safer. When you attach the plastic bracket to the pods, the bracket helps to line the pods up perfectly. Finished product looks flawless. Finally, I decided to route my speaker wires through the plastic bracket grill into the Pak. From the Pak I then went through the bottom of the Pak. Harley instructions want you to route the speaker wires out of the inner side of the pods. This leaves exposed wires and looks tacky in my opinion.
In conclusion, unless you have done this install a couple of times before, I would start with a small hole and go bigger as needed. I believe this only added an extra hour total to the install. If you mess up that hole, you may see it on the side of the Pak.
Good luck, and if you want any pics of the installed pods let me know.
Mach1 is offline
post #5 of 7 (permalink) Old 11-25-2015, 06:24 PM Thread Starter
Q-Hog's Avatar
Pic will help. Thx. you can send them to my email ([email protected]). I tried lining them up and the bolt holes are real close to the edge of the t/p, not close to how it's illustrated in the diagram.
Q-Hog is offline
post #6 of 7 (permalink) Old 11-25-2015, 09:02 PM
Mach1's Avatar
Email sent.
Mach1 is offline
post #7 of 7 (permalink) Old 11-26-2015, 09:48 AM Thread Starter
Q-Hog's Avatar
Thx for the pics and info..
Q-Hog is offline
Tour Pak Speaker Pods OldNerdGuy Audio 2 06-29-2018 05:40 PM
WTB Tour Pak Speaker Pods Shrug Wanted! (Buy or Trade) 1 04-30-2016 01:28 PM
Speaker Pods, Tour Pak Mounts, Flame Hwy Pegs Rrbgeb Parts for Sale 5 02-23-2015 11:39 AM
Dragonfly Customs Tour pak Speaker pods w/ polk speakers sedonaRG Parts for Sale 0 04-08-2014 10:53 PM
WTB Rear Speaker Pods for King Tour Pak jimmyray11349 Wanted! (Buy or Trade) 1 12-15-2011 11:25 PM
