Audio questions, need help. - Road Glide Forums
post #1 of 14 (permalink) Old 11-29-2015, 04:44 AM Thread Starter
I would like to install J and M 360 watt amplifier with 4 speakers and 2 kicker subwoofers 150 watt rms each. I think i will install 2nd amplifiier for the kicker subs. Headlight and taillight are LED now. So question is how much watt is 2012 FLTRU stator???
666blondin is offline
post #2 of 14 (permalink) Old 11-29-2015, 10:09 PM
The stock stator is 50 amp. At 14v that would be 700watts. You have to subtract whatever your bike is using to run from that to get available wattage for audio.
Lvjunior is offline
post #3 of 14 (permalink) Old 12-01-2015, 11:44 PM Thread Starter
Thanks for quick answer and very useful info. I cant find any info how much watt is needed for J and M 360 watt, 4 Channel Amp is a full range class D amplifier and puts out 90 Watts RMS per channel (360w total) driven continuous into a 2 ohm load @ 14.4vdc. Let me know please!
post #4 of 14 (permalink) Old 12-02-2015, 04:00 AM
09Sharknose's Avatar
I'm not sure exactly what info you're looking for as far as available wattage. In theory, as long as the amp is getting the recommended voltage (14.4vdc) it will supply the advertised wattage to the speakers. The amp's INPUT is voltage, OUTPUT is in watts to the speakers. @14.4vdc it will perform as advertised, any less, say with a weak battery or inadequate charging system, it will supply less. Any more, you risk burning up your amp.
09Sharknose is offline
post #5 of 14 (permalink) Old 12-02-2015, 06:49 AM Thread Starter
What i need to know is how much watt power takes 360 watt j and m amplifier in normal working rms condition from stator which is 700 watt power. What i mean is if i install j and m amplifier which is 360 watt and one more 500 watt amplifier how much watts they will take from stator together. That would not be 860 watts am i right.?
post #6 of 14 (permalink) Old 12-02-2015, 08:48 AM
pipe3214's Avatar
Ask chris Lowe or Christopher Scot Gohn. Or ask J&M.
pipe3214 is offline
post #7 of 14 (permalink) Old 12-08-2015, 10:45 AM Thread Starter
So 360 watt j and m amplifier in normal working rms condition takes 12 am
post #8 of 14 (permalink) Old 12-08-2015, 01:50 PM
It's not going to take any watts from anything. Your audio wattage is produced within the amp itself. In regards to your audio system, what your charging system sees is an increased load due to an increase in electrical accessories being powered by the system. The more important number is amperage draw. I think the stock charging system is 50 amps. I'm not sure what the amperage draw of J&M amps are, but one or two motorcycle amps can be easily supported by the stock charging system.
I run three 400 watt amps, 8 speakers and a subwoofer off my bike. I did upgrade to the HD upgraded charging system, but only because my voltage regulator went out under warranty and HD only charged me the difference in price of the additional parts.
post #9 of 14 (permalink) Old 12-10-2015, 09:16 PM
JMJOHN
JMJOHN's Avatar
sharknose ,,,,,,
good post ,,,,
the J&M amps 360 & 500w RMS draw around 10-14 amps average at max volume ,,,,,,
NOTHING that the stock charging system can't handle ,,,,,,,
but when Harley BoomII starts adding 3 and 4 amps to the bike, that is when things can get out of hand ,,,,,,
JMJOHN ----
JMJOHN is offline
post #10 of 14 (permalink) Old 12-11-2015, 11:15 AM
pipe3214's Avatar
J&M make great stuff. I liked mine. But went to alpine and was less $$ and sounds better. Not as easy to wire the amp as the j$m tho :-(
pipe3214 is offline
attention Audio gurus need HELP Jims79FLH Audio 10 08-26-2015 09:08 PM
LIVE! Need help with audio instal in progress! LIVE! Hog Indo Audio 15 05-21-2015 02:23 PM
Need help trouble shooting audio issues hd4cruzin Audio 5 08-10-2013 10:52 PM
I need help with my audio setup jeffreyjjc Audio 2 04-28-2013 10:57 PM
Buying my bike tomorrow and need help with questions. Boxercop New Members Welcome Area 52 03-01-2013 03:24 PM
