My AV Aquatics Head Unit Install - Road Glide Forums
post #1 of 4 (permalink) Old 11-30-2015, 04:40 PM Thread Starter
cobra206's Avatar
I thought that I would share my experience installing the new AV Aquatics head unit. I am by no means a mechanic by trade, but I would consider myself to be an above average do it yourselfer...
So to begin I removed my outer fairing and started disconnecting all the cables to the head unit.
Then I removed the mounting screws to remove the head unit itself...( I find adding some windex to the gasket helps it pull out easier)
File Type: jpg ImageUploadedByMotorcycle1448923183.511431.jpg (14.8 KB, 45 views)
cobra206 is offline
post #2 of 4 (permalink) Old 11-30-2015, 04:44 PM Thread Starter
cobra206's Avatar
Once the head unit is out
I just slipped the new on in... It's important to note that the stock Harley head unit slides out the back and the AV unit slides in from the front
Again I added some windex applied by finger to the gasket to help it slide in. I have read that some people had some issues getting the unit in place. Mine went in with a little wiggling...
Once it seated just used the stock hardware to secure it in place...
cobra206 is offline
post #3 of 4 (permalink) Old 11-30-2015, 04:50 PM Thread Starter
cobra206's Avatar
As for the audio connections... I am using the J&M XT amp... As the amp uses rca connections from the amp to the head unit, it was just a matter of connecting the amp RCA's to the AV RCA's. I chose to use the RCAs to make the connections easier as all I had to do was remove the J&M RCA to wire adapter...
ImageUploadedByMotorcycle1448923673.240061.jpgImageUploadedByMotorcycle1448923683.704983.jpg
U have the choice to use either the RCAs or u can use the stock speaker lines that are in the 23 pin connector (front) and if u have rear speakers attach the leads to the included harness that clips into the back of the unit...
Then just arrange ur wiring
cobra206 is offline
post #4 of 4 (permalink) Old 11-30-2015, 04:57 PM Thread Starter
cobra206's Avatar
Before closing everything up, make sure everything is working
I few points
I would note that as I use my Zumo 665 as my satellite radio receiver I used an RCA to 3.5mm pin cable connected to the rear audio in plugs.
Through the settings u can turn off the internal amp if u are running an external amplifier.
Overall I'd say this is one of the easier installs I have done and I like the set up much better then stock...
cobra206 is offline
Aquatic AV Head Unit let me down gradually bigshaqa Audio 14 08-16-2018 07:32 PM
New Aquatics Head Unit Speaker Wiring ? cmbauer99 Audio 4 10-17-2017 11:41 PM
is the Aquatic AV head unit worth it?? jamminjames New Members Welcome Area 10 11-14-2016 03:28 PM
Aquatics AV install bigshaqa Audio 15 11-18-2015 01:09 PM
AV Aquatics Jims79FLH Audio 13 10-11-2015 12:38 PM
