$25 solution for HANDS FREE operation of PTT - Road Glide Forums
 10Likes
post #1 of 15 (permalink) Old 12-08-2015, 07:31 AM Thread Starter
Spazz's Avatar
$25 solution for HANDS FREE operation of PTT UPDATE (04/29/18)
UPDATE" 04/29/18 - dead links from postimage updated
I was talking to a couple guys online about this...and seemed to be a worthwhile trial run... so why not.
The ONLY thing our 2015/2016 RG/RGS's are missing for PTT is a microphone...so taking some advice from others with 'tinkeritis like me... I dove right in to make this work.
I did a little research on noise-cancelling mics and found the Olympus ME52W was a good overall choice from the reviews I have read for such a small unit... I wanted it small, not too bulky and able to angle it... this was it. $18 at Best Buy.
Now I needed a 3.5mm jack... small and compact. 2 pack at RadioShack for $4 here is the jack and mic...
Using the wiring diagrams in the Service Manual and following the positive and negative leads for the microphone... they lead to pin#1 (RED) and pin#3 ( Black ) on the P&A Audio connector. ( TAN PLUG on top of the radio... NOT THE BLACK ONE )
I unpinned the #1 and #3 leads from the P&A Audio connector and to test everything before I hard-wired, I used alligator test leads to hook it all up... it worked! ( crude pic, but you get the idea )
The best unsightly location for the mic jack was dead center just above the HU... out of sight...and out of direct wind. So I drilled a hole and found the plastic to be almost 3/16" thick there... so I had to recess the jack a little into the besel.
After test-fitting the jack... it all came out.. I soldered all connections, insulated connections and jack and installed the jack and PRESTO! I have a fully operational PPT mic mounted on my RGS.
I have used it in the garage to test for phonecalls and I was told it was crystal clear on the other end.
FURTHER TESTING... 75mph with a Thunder Header... wife on phone at home hears me perfect with no noise... I have to talk loud, but she can't tell.... I do have the Arc 600.4... so this helps with hearing and carrying on a conversation. Some adjustments to volume and settings within the HU may be necessary to achieve a quality sound.
I tested a few voice commands and works for music and navigation... though I don't know all the commands yet.
I know more now.... navigation commands can be done in one long sentence.. works like a charm! Change your radio station.... change to next song on usb stick and much much more!
For less than $25... you can't beat it.
UPDATE: 10/17/16- links were broken, I fixed them. ( thanks Photobucket ! Broke again)
UPDATE: 10/10/17- pics are now on postimage....
RENO BAGGER AUDIO
Spazz is offline
post #2 of 15 (permalink) Old 02-22-2016, 11:42 PM
beatlesfab4fan's Avatar
any updates on how it is when riding? I am tempted to pull the trigger and do this, but I dont want to drill into the fairing if it only works when the bike is sitting or with the motor off.
Thanks in advance,
Mike
RGReno likes this.
beatlesfab4fan is offline
post #3 of 15 (permalink) Old 02-23-2016, 12:55 AM
hifiho's Avatar
Plugging that mic (or another) into an extension wire, and clipped inside a full-face helmet or on a boom mounted to your chinstrap on a half-face might work. I see it's got a foam wind guard on it. Those will sometimes amplify wind noise. But it might be an option, since you've already got the hardware in place. You can also get a throat mic, that is immune to wind noise. Don't give up. I'm a cheap bastard, and I like to cut corners wherever possible. I'll be subscribing to this post. Thanks for the "head's up", Spazz!
'15 Road Glide Special...'08 Night Rod Special...'04 Stage 4 113 CI Softail Deuce (Beast Mode)
hifiho is offline
post #4 of 15 (permalink) Old 02-28-2016, 08:08 PM
I added a mic to mine so i could do the same. i bought a mic on ebay that was deigned for this. worked well.
RidinNY is offline
post #5 of 15 (permalink) Old 10-05-2017, 09:21 PM
InlineR's Avatar
Hi spazz I found this after looking at your soundz audio thread.. any chance of updating the links?
thanks man
looks like Ill be buying some new speakers soon enough...
2017 Harley Davidson Road Glide Aggressor Factory 47 Signature Bars Factory 47 Bag Guards Klockwerks Advan Black Extended Bags Cobra 909
InlineR is offline
post #6 of 15 (permalink) Old 10-06-2017, 09:55 AM Thread Starter
Spazz's Avatar
thanks man
I will try to get to it... gimme some time
Sent from my SM-G955U using Tapatalk
RENO BAGGER AUDIO
Spazz is offline
post #7 of 15 (permalink) Old 10-10-2017, 09:34 AM
Dont see any links...
Does this allow me to use my Phone throught he BOOM system while I am riding and listening to music? A YT video would be cool if you can find some time to make one.
kaptkaos is offline
post #8 of 15 (permalink) Old 10-10-2017, 01:24 PM Thread Starter
Spazz's Avatar
I have to relocate pics from Photobucket to imagepost.... I have 4 years worth of crap that surfaces like this... I get to them when I can...i will get pics transferred tonight... I have time open today...
Yes... you can also take calls thru the Boom as well
RENO BAGGER AUDIO
Spazz is offline
post #9 of 15 (permalink) Old 10-10-2017, 02:42 PM
Spazz is the king of cool ass youtube vids. I still think that gear360 is over the top. BTW nice 80's throwback with KoolMoeDee.
Mike
Spazz likes this.
post #10 of 15 (permalink) Old 10-10-2017, 02:53 PM Thread Starter
Spazz's Avatar
Mike
Hahaha... you like that huh? Lol
And thanks
RENO BAGGER AUDIO
Spazz is offline
Operation Octane Nordic Berserker General Off-Topic Discussions 15 12-14-2016 11:14 AM
Pre-Rushmore Hands-Free Phone Options??? stackrat Audio 5 07-21-2016 03:52 PM
Operation Personal Freedom - Free HD Riding Academy (Free endorsement) PHX_TVS Active Military and Veteran's group 1 05-10-2015 06:10 PM
HELP with PTT button/garage door opener longrides *General Road Glide Discussions/Pictures 10 04-30-2012 06:45 PM
