JBL GTO638 and Sound Stream PN4.520 D Questions - Road Glide Forums
post #1 of 22 (permalink) Old 12-20-2015, 01:48 PM Thread Starter
Afternoon!
After reading other posts I still have questions regarding how to install these speakers and amp on my 2012 RGU.
  1. Will the GTO638's fit in my rear speaker pods?
  2. Are adapter rings required for the fairing or pod speaker installs?...I do not believe so, but some one did mention using them in a post I read.
  3. Will sound damping improve the sound in either the pods or fairing?
  4. If sound damping improves either location, what product did you utilize?...pictures?
  5. According to what I have read, the amp can be installed under the head unit, velcroed above or zip tied below the head unit...any other ideas? How did you install?...pictures?
  6. I am also installing a 665 Zumo. I think I understand the best place to mount the XM radio puck is on top the head unit. Any advice considering the amp install?...lessons learned when you installed?
  7. Could I run both the garmin and the amp off the head light pigtail?...I could make a splitter. Maybe better to tap the ACC / Lighter power in the fairing.
Thanks for any advice / pictures. I'm installing the GPS (Iron Aces Mount), Amp, Speakers and XCycle Fairing Trim the week after Christmas. Can't wait till Spring!
12 Road Glide Ultra - Ember Red Sunglo
98 Heritage Springer - Blue on Black
06 Yamaha FJR1300 - Dark Purplish Blue Metallic
GRider is offline
post #2 of 22 (permalink) Old 12-20-2015, 10:11 PM
Swomack's Avatar
I have a 2015 RGS and didn't need adapters to install the JBL's.
Removed the covers, removed the stock speaks, plugged in the new JBL's and was good to go. I still haven't installed a amp because I waiting until I purchase a removeable King Touring Pack. Once I pull the trigger this coming spring I will purchase another pair of the JBL's and install them in the speaker pods for the touring pack. The removal of the stock speakers to the 6.5" JBL's is a 15 minute job from start to finish. I can hear my music going 70+ also using a 14" Klock Werks Sports Flair windshield without any issues.
Swomack
My Gallery / Click Below Link
Swomack is offline
post #3 of 22 (permalink) Old 12-21-2015, 01:50 AM
immo2896's Avatar
I just installed this amp tonight on my 2011RGU. I used Velcro from Lowes to put it on the right side between the pocket and inner fairing. I put it as high as it would go. I didn't take any pictures because I was too lazy to go get the camera. I ran a fused wire and ground from the battery, and with this amp I did not need a remote wire. I used the high level inputs from the stock radio.
immo2896 is offline
post #4 of 22 (permalink) Old 12-21-2015, 04:57 PM
the88virgnian's Avatar
You should be able to run those speakers in the rear pods with no issue. I have 6.5 in speakers in mine with no issue. You will need adapter rings for the front fairing, however. As for the amp, unless your removing and swapping out the stock head unit, I don't think you'll be able to install it up there. You'll probably need to either go with the heavy duty Velcro and mount it to the sides, or buy a bracket. If you have any other questions, feel free to ask. I have a 13 RGU
2013 RGU BBP. Detachable Tour Pack, aftermarket slip ons (no name), Wild 1 WO612s, Avon Cushion Grips, 13" Madstad, Kenwood Excelon x799, 8x DD Speakers (4x VO-M, 2x CXS 6.5, 2x B3), Diamond Micro 4v2 Amp.
the88virgnian is offline
post #5 of 22 (permalink) Old 12-21-2015, 05:18 PM
09Sharknose's Avatar
You will need adapters for the front fairing and most likely in the tourpak pods if they are stock HD pods. The only speaker locations set up to receive 6.5 speakers on 2012s are the lowers. You may be able to get some speakers in to the rears, but not as a rule. Virginian above says his 6.5s fit without an adapter. You may want to ask him which ones he's using. I have focals and hertz and neither of them fit into the rear tp pods. Alpine SPRs have good sound and a significantly smaller magnet than some of the top tier speakers, so that's a suggestion.
09Sharknose is offline
post #6 of 22 (permalink) Old 12-23-2015, 06:50 PM Thread Starter
Thanks for the feedback...looks like I am going to need adapters after all.
I appreciate the heads up! Merry Christmas!
GRider is offline
post #7 of 22 (permalink) Old 12-23-2015, 07:39 PM Thread Starter
I just ordered 4 Arc Audio 6.5" adapters. They weren't cheap but the reviews were strong so pulled the trigger. I'll post feedback after I install!
GRider is offline
post #8 of 22 (permalink) Old 12-24-2015, 08:11 AM
immo2896's Avatar
I paid almost 50 bucks for a set here at a local shop. I thought it was way too high, but I wanted them right then, instead of ordering them online. Paid for convenience.
immo2896 is offline
post #9 of 22 (permalink) Old 12-25-2015, 08:07 AM
The fairing adapters are not the same as the tourpak adapters. The fairing adapters mount to the front of the speakers and allow you to screw the 6.5 speaker in place where the 5 1/4 holes are. The tourpak adapters mount to the tourpak pods and provide offset between the speaker pods and the speaker to account for the larger speaker size and magnet.
post #10 of 22 (permalink) Old 12-28-2015, 03:09 PM Thread Starter
09Sharknose...do you happen to know the brand of adapter I will need for the rear pods? I have been searching, no luck yet. If I find a brand I will post back.
Thanks for letting me know Man! Sheesh, getting closer but still a long way to go!
GRider is offline
Jbl gto638 Willy_B Parts for Sale 1 06-22-2018 12:43 PM
JBL GTO638 6.5-Inch 3-Way Speakers tlottman Audio 176 01-06-2018 05:48 PM
Blown JBL GTO638 SquirtRGU Audio 4 02-27-2016 08:06 PM
JBL GTO638 GTO Speakers Gary R Parts for Sale 7 12-02-2015 07:31 AM
