2015 / 2016 Road Glide Speaker Fitment Success and Failure - Road Glide Forums
 17Likes
post #1 of 68 (permalink) Old 12-20-2015, 07:05 PM Thread Starter
wevsspot's Avatar
2015 - 2018 Road Glide Speaker Fitment Success and Failure
I don't know if anyone has posted something similar before but I wanted to start a thread showing the known speakers that will and/or will not fit in the 2015 - 2018 Road Glide Fairing.
Fit - Yes
Alpine SPR-60
ARC Moto 602 (remove the rubber ring, confirmed through Arc Audio that it's purely cosmetic) - thanks Bunker!
ARC Moto 602HD
Audio Dynamics ADCX621
Beyma pro 6.5 mid drivers
Biketronics 2015 Road Glide Kit
BT465
Focal 165KRC
Focal PC165
Hertx ECX 165's (remove cover from magnet) - thanks TVH475!
Hertz Millie Pro 165.3 (remove cover from magnet and may require tapered speaker ring spacer from BT or minor grinding on one of the ribs inside the pod)
Infinity Kappa 62.11i
Infinity Kappa 62.ix
JBL GTO638
JL C3 650
J&M 2015 Road Glide Kit
Fit - Yes - Requires Some Modification
DB DRIVE WDX6MOTO-G2 - Had to cut a hole in the side of the pod and remove cover from magnet
DD VO 6.5's - Had to cut a hole in the side of the pod, covered the hole and the exposed magnet with dynamat
Focal ES165KX2 - Had to cut a hole in the side of the pod, covered the hole and the exposed magnet with dynamat
Hertz SV165's - Had to cut a hole in the side of the pod, covered the hole and the exposed magnet with dynamat
Hertz HCX165 - See information beginning with post #38 (remove cover from magnet and requires BT tapered speaker ring spacer)
MMATS PA601.4cx - Had to cut a hole in the side of the pod, covered the hole and the exposed magnet with dynamat
MMATS PA601.cx - Had to cut a hole in the side of the pod, covered the hole and the exposed magnet with dynamat
Fit - No
American Bass 6.5 mid drivers
Cerwin-Vega V465
DS18 Pro's (I believe they were PRO-X6.4BM)
DB WDX6MOTO
If others are interested in providing your confirmed successes or failures I can create a Google Docs spreadsheet and keep it updated.
wevsspot is offline
post #2 of 68 (permalink) Old 12-23-2015, 11:34 AM
The J&M kit works great and its plug and play
AFD68 and yanx73 like this.
If the Sun comes up you get another chance! Don't Worry
RGS15 Steve is offline
post #3 of 68 (permalink) Old 12-23-2015, 12:11 PM
Biketronics kit is total plug and play. Didn't cut or splice any wires. No dealer flash required when using their line leveler. AND, the system screams. At times momma tells me to turn it down while doing 80 down I-95
gplatt58 and speedkills66 like this.
MisterD is offline
post #4 of 68 (permalink) Old 12-23-2015, 12:31 PM
Spazz's Avatar
Focal 165KRC's fit perfect...
RENO BAGGER AUDIO
Spazz is offline
post #5 of 68 (permalink) Old 12-23-2015, 12:51 PM
Q-Hog's Avatar
I'm looking for a rca or line converter for my RGS to work with the Arc Moto amp. Any recommendations?
Q-Hog is offline
post #6 of 68 (permalink) Old 12-23-2015, 01:29 PM
Khaotic's Avatar
Did you mean this?
2014+ HD Adapter Harness*| Arc Audio
2016 FLTRXS 120ST, SE Elite Heavy Breather, D&D Boss Boarzilla, Bandit Sportsman Clutch, Factory47 16" Malo and Arc Audio MPAC 6.
Khaotic is offline
post #7 of 68 (permalink) Old 12-23-2015, 04:26 PM
Q-Hog's Avatar
Thx. I will need that as well.
Q-Hog is offline
post #8 of 68 (permalink) Old 12-23-2015, 06:04 PM
Swomack's Avatar
I run the JBL's and yes they fit right in without issues.
My Gallery / Click Below Link
Swomack is offline
post #9 of 68 (permalink) Old 12-24-2015, 06:29 AM
you could get one of these and then fit JL Audio 7.7's
https://www.facebook.com/Infamouscustomsaz/
Bunker is offline
post #10 of 68 (permalink) Old 12-27-2015, 10:18 AM
What is this? We're do you get them?how much do they cost? Is there other configuration? I would like to be able too run some high quality 3 way separate speekers
dozer23 is offline
Water Pump Failure and Repair / 2016 RGU (Lots of Pics) Kennyd Fluids and Lubricants 39 09-16-2018 04:52 AM
2016 Road glide J&M Rokker Extreme failure Steven B Dickens Audio 1 07-12-2017 11:54 PM
Progressive Shocks a Complete Success!! Zzzen Dog Suspensions 5 03-15-2011 08:04 AM
