In line fuse for amp - Road Glide Forums
 3Likes
  • 2 Post By Smarty
  • 1 Post By bucketlisthd
post #1 of 8 (permalink) Old 12-27-2015, 08:56 AM Thread Starter
2015 RGS, Kenwood M1804 amp, what size fuse should I run in my in line fuse link, Ive read where some are 40amp and some are up to 60amp,
03rkjc is offline
post #2 of 8 (permalink) Old 12-27-2015, 09:53 AM
I am not a audio expert but that amp is a 4 channel amp and the audio system on the Harleys are 2 ohm systems so make sure it is compatible.
I would think that a 20 or 25 amp fuse would be sufficient, the main fuse on the bike is only 40 amp and the charging system is 50 amp max.
post #3 of 8 (permalink) Old 12-27-2015, 10:40 AM
Smarty's Avatar
You should look at the size of the fuse in the back of the amp. Normally about a 40 amp fuse. Then put a 25 amp at the battery on the wire going to the amp. That way if something goes wrong, the 25 amp blows first and you are not taking the fairing off to check a fuse. Ask me how I know this! lol
Jayray and 9over like this.
Smarty is offline
post #4 of 8 (permalink) Old 12-27-2015, 11:28 AM
bucketlisthd's Avatar
Yup.
Smarty likes this.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #5 of 8 (permalink) Old 12-27-2015, 12:31 PM Thread Starter
The fuse at the amp is a 15 amp. I thought that sounded small
03rkjc is offline
post #6 of 8 (permalink) Old 12-27-2015, 12:45 PM
09Sharknose's Avatar
There should be a recommended in line fuse size in the manual for the amp.
I have 30amp fuses in all 3 of my amps.
09Sharknose is offline
post #7 of 8 (permalink) Old 12-28-2015, 08:31 AM
Smarty's Avatar
That is very small for the fuse in the amp. I would read up and make sure it is correct.
Smarty is offline
post #8 of 8 (permalink) Old 12-28-2015, 10:43 AM
9over's Avatar
To protect your system use the smallest amperage fuse that will keep the system operating and in a location you can access easily.
One would think that the manufacture would recommend what will work.
9over is offline
Lost All Sound, Blowing Amp Fuse The Volusianator Audio 24 06-29-2015 07:08 PM
P & B fuse blows chevelledude Troubleshooting for Road Glides 6 01-06-2015 08:19 PM
Blowing in line fuse Hawg Wire Amp ?? redbaron Audio 3 04-06-2014 11:18 AM
P&A Ignition Fuse? Nickster Tech Area 3 04-10-2012 04:30 PM
40 amp main fuse twowheel99 Do-IT-Yourself 4 03-05-2011 05:55 PM
