My speaker system skips! - Road Glide Forums
post #1 of 2 (permalink) Old 12-27-2015, 11:38 AM Thread Starter
I recently did an upgrade to my 05 RG. Did the following:
o power acoustik CA4-1600D amp,
o alpine Type S 6.5's.
o kenwood KMR-M312BT
When my bike is at the on position, the speakers sound great. Nice loud and crisp. BUT as soon as I cut the bike on and try to reach the same volume, it'll start to skip as if I have a bad CD playing. I usually play with Bluetooth, or USB. Max volume is 35 and I can only play at 29 before music starts to skip.
I've contacted crutch field for their advice and other audio shops. I don't know what else I should do! Has anybody else experience this? If so what did you do???
Thanks in advance
C Square is offline
post #2 of 2 (permalink) Old 12-27-2015, 05:43 PM
the system is probably clipping Im not familiar with your amp if it has a gain control try turning it down until the problem goes away . you may also want to check voltages when running and not running make sure your not under power when bike is off or over with bike running
2001 Road Glide Jade Sunglo , carb and stock
Eagle is offline
Tested my audio system today on my ride. Heavy Metal Audio 3 02-05-2018 08:24 AM
Full SE vs VH Exhaust System w/ Stage 2 Sound System RoadWolf1172 Intake and Exhaust 23 12-26-2017 01:33 PM
Finally got my system in my 2016 RG. HawaiianBuddha69 Audio 2 07-06-2017 07:59 PM
Figured out BT and got it working... but skips, wtf? thealaskan Audio 3 09-29-2015 04:45 PM
Engine skips on roll-on after deceleration intermittently. KiloGolf4 Engine Related 4 08-19-2014 09:53 PM
