blowing tweeters? - Road Glide Forums
post #1 of 7 (permalink) Old 12-28-2015, 08:04 PM Thread Starter
blowing tweeters?
I installed the jl audio hx280/4 amp (Bridged) and an LOC on my 15. I had the dealer flash and it made a world of difference.
My question is: has anyone had an issue with what is best explained as "blowing the tweeters" of the speakers? They just started to sound muffled. I have had this happen twice now. Once on a set of Morel ultra integra 6.5 and now on a set of Hertz mpx 6.5.
jcalvinm is offline
post #2 of 7 (permalink) Old 12-28-2015, 09:02 PM
09Sharknose's Avatar
The only thing I can think of is that your amp bridged into a 4 ohm load is rated about 40% more power than the speakers.
09Sharknose is offline
post #3 of 7 (permalink) Old 12-29-2015, 06:27 AM
Jcalvinm: I run that amp with the biketronics line leveler and there titan II speakers and have not had a problem.i think shark nose is right to much power to those speakers,I think the line leveler cleans the signal better than the flash. I hope your speaker vendors are making things good.if you bought on amazon you should be O.K. titan II are waterproof and guaranteed for life 179.00 made by Hybrid audio technology
dozer23 is offline
post #4 of 7 (permalink) Old 12-29-2015, 09:10 AM Thread Starter
Thanks guys, the speaker vendors are taking care of me luckily. I am also going the BT-355 route and forgoing the flash and the line out converter i was using. I really hope that does the trick and I don't ruin another set of speakers!
jcalvinm is offline
post #5 of 7 (permalink) Old 12-29-2015, 07:34 PM
JL amps are very efficient! you are pushing a true 140 watts to each channle.my gains are set just under 1/2 so far so good.good luck!
dozer23 is offline
post #6 of 7 (permalink) Old 12-29-2015, 08:24 PM
Just for the record, I run that same amp bridged into a set of 6x9s rated at 130w/RMS each. I would be hesitant to run that kind of power full throttle into a set of 6.5s.
post #7 of 7 (permalink) Old 12-30-2015, 07:04 AM
Yup! JL hx 280/4 is a powerful little amp.I have it running a pair of 6.5s I bet it could drive lowers. when I do them.not sure how I would wire them. Some day.
dozer23 is offline
Added RF tweeters and kept gauges creed Audio 2 04-21-2012 12:16 PM
What size tweeters? GLYDDN11 Aftermarket Accessories 6 10-27-2011 07:12 PM
Hard Ride Audio Road Glide Tweeters PC PaiN Audio 0 10-06-2011 11:13 PM
2012 cvo spaekers and tweeters THEMASTERDESTROYER Audio 10 08-12-2011 10:50 PM
Tweeters? Ny Chief Audio 0 06-15-2011 02:57 PM
